Old Jun 25, 2008, 08:07 PM
gramps45 is offline
Find More Posts by gramps45
sorry to ask the same question again but is the dihedral for the bb33 uc wing 1" under each wing tip? and 1 1/2" with one side of wing flat on table for the kfm3 wing? i'm going to write it down this time.
thanhs
gramps
gramps45 is offline Find More Posts by gramps45
Old Jun 25, 2008, 08:39 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
I think I posted this before, but here's mine. 'Course you have to be willing to put hot melt on the camera surface . Done this to two cheap cams so far. I screw the hxt5gm servo with a cut down arm to the piece of 1/8th ply and hot glue the ply to the cam face, insuring that the arm is setting correctly to trip the shutter button.
springer is offline Find More Posts by springer
Old Jun 25, 2008, 09:12 PM
Hopalong X is offline
Find More Posts by Hopalong X
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
thanhs
gramps
BB-33 UC is 1.5 inch under each side according to Tony's plans.
KFM-3?
It appears the KFM-2 BB-33 is also 1.5 inches per side. There is only one measurement on the plans and the plans work for both wings on the BB-33 unless Tony has altered the plans recently.
I found the KFM-3 sport wing!! That is a new one for me.
It isn't marked on the plans.
Hopalong X is offline Find More Posts by Hopalong X
Old Jun 25, 2008, 09:24 PM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Here's a question for all you experienced flyiers out there. What size wheels work well for a 42" BB landing on a rough grass field? The field is mowed, but its low quality grass with some balding areas. What do you think?
BlueFFF
BlueFFF is offline Find More Posts by BlueFFF
Old Jun 25, 2008, 09:27 PM
laserman is offline
Find More Posts by laserman
In Rc for a LONG TIME FFAA#1
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
that is nice but i don't want to glue anything to the cam. i am looking for something that will fit over my cam if some one has done something that slips over the cam and is held on with rubber bands would be perfect
last
laserman is offline Find More Posts by laserman
Old Jun 25, 2008, 09:29 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
BlueFFF
I have 2.25 on my SuperCub which is basically a BB-42 size fuselage. I could easily go to 2.75 and still look like a bush plane. Use the foam wheels. I have the Dubro rubber ones in a 2.5 and 2.75 and they are way too heavy.
I took the smaller SuperCub wheels and put them on my BB-33. No waste!
laserman is offline
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
BlueFFF
if you got some long streaches that are bald ( hopefully not on your head lol ) some 1.5 to 2.0 inch wheels will work, if there is low cut grass go to 2.5 - 3 inches or 3.5 if its longer
Old Jun 25, 2008, 09:37 PM
springer is offline
treefinder
springer's Avatar
SE MI
Blufff: My 42" sports 2.25" wheels and I fly off orchard grass cut to about 3" (pretty coarse) and they are marginal. She will want to nose over unless the grass is fresh cut. (I usually do a hand launch, don't bother with rog)
Just got a pool noodle and may try making wheels out of it as some have done, think they will come out about 3" and should be super light.
Laser: I figured that most won't want to glue their cams. Perhaps if you make the ply fit over most of the front surface and another piece over back surface screwed or rubber banded together, sandwiching cam in between. Will need a way to insure registration of servo to button, tho.
Old Jun 25, 2008, 09:39 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Did you ever get that Corsair in the air?
Old Jun 25, 2008, 09:44 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Now that sounds like an interesting solution. $ store is getting a visit tomorrow. ...and I have about 20 rims that need new rubber/foam!
Old Jun 25, 2008, 09:48 PM
laserman is offline
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
not yet just got another rx for my dx 6 ( and i am waiting for the battery booster to arrive gives the dx6 a 5.5 run time instead of 2 hour) if you have a question on that let me know on what needs to be done for this mod to your spektrum dx 6
Old Jun 25, 2008, 10:05 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
That 2.4 stuff is too rich for my pocket book. Now if it helped my flying skills then maybe.....
I did get a short flight with my Bb-33 finally....then I dumb thumbed it on a turn. Left and down didn't work well.
Broke the motor mount and prop. It is glued back together but too much wind today.
Old Jun 25, 2008, 10:07 PM
laserman is offline
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
mike
real fun part of this the part is only .25 cm thick x .5 cm x .75 cm and costs only 15 $
Old Jun 25, 2008, 11:41 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
BB33 Landing gear.
Need some input, What size wire have you guys been using for the landing gear on the BB33? I have .045 (seems way to small), .054, .060, .076 (seems way to big). I am thinking the .060 would suffice. Would this be to stiff? I have the Dubro 1-3/4" Super lites for tires. I hope they aren't to small, they looked big on the peg at the LHS but now that I have the fuse built they seem small.
Any way, what do you guys think on the gear?
Rob...
mxspode is offline Find More Posts by mxspode
Old Jun 26, 2008, 12:08 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Wheels for grass: larger diameter is better. There are two approaches: really skinny ones to cut through the grass (like some of the spoked park flyer wheels) or really fat ones to go on top (Trexler balloon wheels). Both approaches work. The skinny parkflyer wheels are lighter and much less expensive and lower drag.
Gear wire diameter: at least the .062 stuff (1/16 inch). Depending on how heavy your airplane is, the .078 might be better (though for that you'll have to ream out those DuBros). But then, I expect the landing gear to work and hold up on my planes, so I tend to go higher. See my post a few pages back showing an alternate gear arrangement as borrowed, unchanged, from the Stevens Aero SQuiRT and SHAFT series of models.
Dihedral for the 33 inch KFm3 sport wing: I'm starting on one of those right now. In this post Tony said "at least 1/2 inch per tip". That's about 1.7 degrees of dihedral. Obviously if you were going to go three-channel it should be more like that of the UC wing.
BEC is offline Find More Posts by BEC
Last edited by BEC; Jun 26, 2008 at 12:22 AM. Reason: getting the facts straight, added gear link
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
