Old Aug 30, 2015, 09:41 PM
Jacktstone is offline
Find More Posts by Jacktstone
Joined Jun 2015
Question
Powering Lights through the bind slot
I'm getting a parkzone T28 in a few days. I'm going to add flaps and a bomb drop to it on the provided 6 channel receiver, but then I don't have an extra channel to put my light system on, and I only have a 6 channel transmitter so I can't upgrade to a better receiver. Is it safe to power lights through the bind slot on the receiver?
Jacktstone is offline Find More Posts by Jacktstone
Old Aug 30, 2015, 10:10 PM
taz101 is online now
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
Yes!!
But you can also Y it into any channel.
But through the bind port is fine.
LURCH
taz101 is online now Find More Posts by taz101
Old Aug 30, 2015, 10:14 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
You can power DSM2 and DSMX receivers through the binding port so you can tap power from them too. The only difference between the binding port and all the rest of the ports is the function of the signal pin.
Pete
PGR is offline Find More Posts by PGR
Old Yesterday, 02:04 PM
James_S is online now
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
If you look at the circuit board in any receiver, all of the power and ground pins connect to a trace that runs across the board and ties them all together. All of the V+ pins are connected together and all of the ground pins are connected together. Only the signal pins go to different places.
That means you can power a receiver, or draw power from a receiver from any of the connectors, it makes no difference.
James_S is online now Find More Posts by James_S
Sold Great Planes Power Plane & Slot Machine combo orbsah Aircraft - General - Miscellaneous (FS/W) 3 Jun 20, 2015 09:43 PM
Discussion Turnigy 9x binds fine, but after power off, will not remember bind. Rhymenocerus Radios 4 May 21, 2015 01:56 PM
Help! Battery/bind slot question ggradtech Electric Plane Talk 4 Feb 05, 2014 10:17 AM
Discussion Binding with out going through bind procedure cgblues Xtreme Power Systems 3 May 26, 2009 06:31 PM
