Old Aug 06, 2015, 05:34 PM
Murdock80 is online now
Find More Posts by Murdock80
Outlaw flyer
Murdock80's Avatar
United States, KY, Lexington
Joined Nov 2014
Help!
Prop size for 3536 900kv motor???
I'm running a 3536 900kv motor w/ 30 amp esc on my pkz wildcat. Would anyone have any suggestions for a prop size for this motor and plane combo without toasting the esc??
Murdock80 is online now Find More Posts by Murdock80
Old Aug 06, 2015, 08:13 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
11*8 should draw about 26A on 3s. Verify with a wattmeter!
scirocco is offline Find More Posts by scirocco
Old Aug 06, 2015, 08:30 PM
Outlaw flyer
Murdock80's Avatar
Joined Nov 2014
Thanks buddy. I put a 40 amp esc I had In it just to make sure. I just got my watt meter In and gotta run to my buddy's an get it. I may try a 11x6 3 blade. I'm not sure how it'll act on a belly lander as far as breaking....
Old Aug 07, 2015, 01:38 AM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
Personally I wouldn't choose the 11*6*3 over a 11*8 because with the relatively low Kv the pitch speed will be on the low side for the Wildcat. I'd actually also consider a 10x10 and if you stick with the 40A ESC, 11x10
Old Aug 07, 2015, 05:33 AM
Outlaw flyer
Murdock80's Avatar
Joined Nov 2014
Sounds good bud. The prop that came with the plane originally was a 11x9 but finding this prop is slim Pickens! I figured the low pitch would prolly spin a lot faster for the kv as well. Your input is appreciated scirocco! Now turn up some rose tattoo!!!!
Old Aug 07, 2015, 05:40 AM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
apc has an 11x8.5 you could try. The 11*6*3 is indeed a little less load than 11*8, but only a little and the few extra revs can't make up for 25% less pitch. Unlike glo engines that can unload a lot and rev a lot harder with smaller props, an electric motor's voltage times Kv is effectively a rev limiter. Under load, you'll never see rpm much more than 80% of Kv x battery voltage.
Old Aug 07, 2015, 05:52 AM
Outlaw flyer
Murdock80's Avatar
Joined Nov 2014
Cool. I'm still learning the whole kv prop size wattage motor size thing. When I get my watt meter I suppose I will learn a lot more fine tuning to this. I'll pick up one of these props today at my LHS. Again. Thanks buddy
Old Aug 07, 2015, 05:54 AM
Outlaw flyer
Murdock80's Avatar
Joined Nov 2014
Where this is a belly lander.. The length of the prop won't be an issue?
For Sale used Team Black Sheep 900kv Motor set 4 pieces 4 x TBS Bullet Proof 30A esc + Props Shanya Aircraft - Electric - Multirotor (FS/W) 2 Jul 24, 2015 05:47 PM
Discussion what's the right size battery/prop for this motor capt_kirk Power Systems 5 Jul 12, 2015 03:27 PM
Sold HP2814(3536)-710KV Multi-Rotor Brushless Motor + 1340 props + 1238 props Nettraptor Aircraft - Electric - Multirotor (FS/W) 0 Sep 27, 2014 08:06 AM
Discussion Prop size for ntm 28-30s 900kv? JonnyJ Multirotor Power Systems 1 Sep 14, 2014 12:22 AM
For Sale 3 NTM 900kv motors w/prop adapters, 2 DJI Knock-off 920kv motors BmwMach5 Aircraft - Electric - Multirotor (FS/W) 0 Apr 28, 2014 09:54 AM
