Old Jan 20, 2013, 10:19 AM
prediator is offline
Find More Posts by prediator
Joined Nov 2012
flysky ct 6b throttle always high
It suddenly happened that my ct6b throttle remains high even at lowest stick. I am attaching pics. please help..
prediator is offline Find More Posts by prediator
Old Jan 21, 2013, 01:19 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi!
Could you check if your stick poti is connected correctly to the corresponding cable?
Julez is offline Find More Posts by Julez
Old Jan 21, 2013, 01:57 AM
Joined Nov 2012
hi, yes every things seems perfect, i can update every parameter of the tx, the only issue is with throttle
Old Jan 21, 2013, 08:32 AM
BigIron357 is offline
Find More Posts by BigIron357
25+ years of RC flying
BigIron357's Avatar
United States, FL
Joined Aug 2012
Try reversing the throttle... be sure to remove the prop first as the motor might energize. I had a similar issue when first setting up my CT6B and after I reversed the throttle, it started working. Then I reversed it again back to normal and calibrated the sticks and all worked fine after that.
Best of luck to you.
BigIron357 is offline Find More Posts by BigIron357
Old Jan 21, 2013, 09:18 AM
Joined Nov 2012
thanks, i'll check it out.
Discussion -FlySky FS-TH9X 2.4GHz 9CH Transmitter Elevator and Throttle channels hoeniola Radios 1 Jan 19, 2013 03:19 PM
Discussion Ice 100 cuts off at high throttle delta2001 Power Systems 6 Jan 07, 2013 11:51 AM
For Sale Turnigy 9x, and 2 flysky rs-6b receivers skyjacker07 Aircraft - General - Radio Equipment (FS/W) 12 Nov 22, 2011 02:27 PM
Discussion FlySky CT-6B Dead on Arrival Jack the R HobbyPartz.com 4 Jan 21, 2011 03:49 PM
