Old Jan 01, 2013, 06:25 AM
Pat Byron is offline
Find More Posts by Pat Byron
Joined Dec 2012
Walkera V400D02 / E Sky Belt CP conversion
Hi Everyone
Maybe someone can point me in the / a direction of " HOW TO !!"
I want to remove the complete RC system from a Walkera V400D02, and fit it to a E Sky Belt CP.
A) Start, B) What to do, C) And how.
I am pretty good with the electronic side of this venture, and have experence with Radio Control.
Can't wait for guidance.
Pat Byron is offline Find More Posts by Pat Byron
Old Jan 01, 2013, 06:50 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
I'm using the guts from a Wasp V3 in my HK250GT and it
works great.
Now is as good a time as any to learn this stuff. It took me
about a week of reading and trial and error before I figured
everything out.
Do they both have the same head design? If so, it should drop
right in, I would think. Just do the normal setup as you would any heli,
double check your servo reversing and servos are plugged in to correct
channels. And if your swash is different, select accordingly.
Set up your pitch and throttle curves and set up the blade pitch and gyro,
and check your blade tracking.
I know there is more, but can't think of it.
Make sure the blades are removed for initial testing. in case
something is set wrong.
Steve_ is offline Find More Posts by Steve_
Old Jan 01, 2013, 08:19 AM
Joined Dec 2012
Steve
Thank you for your reply, i am sure there is a lot of differences between the two units.
A) Walkera, Flybarless. E Sky - Flybar.
B) Walkera, Brush motor. E Sky - Brushless
C) Walkera Tail rotor RPM control - E Sky Belt driven - Pitch control.
D) Walkera 3 Axis gyro - E Sky 1.
Is there another communication medium Egg. E-Mail I can then send you pictures.
" I need help here "
Old Jan 01, 2013, 11:52 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
It's a very cool idea, but it may not be worth the effort and expense. Here's a list of things you would need to overcome:
1. The Walkera integrated 3 axis gyro/receiver does not have provisions for handling a belt drive tail. You would need to replace the entire unit and get the components from the V450D01. That will be a major expense. You could also buy all separate components and set it up yourself.
2. The mainshaft is not the same diameter and doesn't have provisions for attaching the drive belt gear. You may get around this with some clever fabrication, hard to say.
3. The stock servos are crap and should be upgraded, regardless.
The basic problem with such a conversion is you really aren't salvaging anything but the head. You could sell the entire V400D02 and buy an aftermarket flybarless head that's better quality. I've been trying to come up with a way to salvage more of the Walkera components, but I'm not coming up with anything that looks promising.
Balr14 is offline Find More Posts by Balr14
Question compatibility betwen E Sky belt cp and Hausler 450p enzo_vzla 3D Electric Heli Flying 0 Dec 05, 2012 09:37 AM
For Sale E Sky Belt CP V2 ( NIB ) chardman Aircraft - Electric - Helis (FS/W) 1 Nov 18, 2012 09:03 PM
Sold great cond e-sky belt cp with a few spares cheap !!! crash8384 Aircraft - Electric - Helis (FS/W) 2 Jun 17, 2012 10:33 AM
Discussion E-SKY's BELT-CP , TIPS & HELP !!!!! WulfmanG Beginner Training Area (Heli-Electric) 9 Mar 15, 2012 12:38 PM
Discussion E-Sky Belt CP CX vs. Walkera HM59#DQ LNLP Micro Helis 6 Jul 22, 2010 12:51 AM
