Old Jun 11, 2013, 11:47 AM
cpmcgraw is offline
Find More Posts by cpmcgraw
Experienced Balsa Mangler
United States, AL, Tillmans Corner
Joined Oct 2012
Progress Report
Starting to get serious with the forward hatch. This is a one-piece windscreen filler, and will be held in place with magnets. I'm thinking about using cardstock for much of the construction, as it is light and stiff enough to hold its shape. The general idea is to pre-paper the cardstock with red, trim out some for the windscreen area, then white glue that over a piece of clear sheet to form the actual piece.
Photos 1 & 2 show the forming process in action. I think the windscreen will look OK...
The nose block is attached, just waiting to be papered.
cpmcgraw is offline Find More Posts by cpmcgraw
Old Jun 17, 2013, 05:54 PM
cpmcgraw is offline
Joined Oct 2012
Progress Report
What should have been relatively easy turned out to be one of the longest-to-complete tasks on the model -- finishing up the landing gear. I have to admit, after getting the gear soldered together, the alignment left a lot to be desired. I will probably rebuild the gear at some later date, just to correct the visibly-obvious offset of the axles. I blame it on my glasses...
Photos 1-3 show the completed gear. For Sundancer, it also shows the simple no-glue retainer that I think turned out great in spite of the alignment issue. I know I will use this method again on Mamselle...
Here's the list of remaining things to do for completion of Envoy:
  • Mount servos
  • Finish pushrods
  • Glue hinges in on the elevator
  • Wire up the ESC and motor to their connectors
  • Finish upper hatch
  • Finish lower (servo) hatch
I will most likely not have the model flying before the deadline, as I still do not have a full radio system to use. The monetary budget has restricted me on such major investments of late; I've only been able to slip in the odd low-end "necessary items" for mechanical completeness...
Still, I'm having fun. Envoy was an exercise of the olde fingers and brain cells, and I expected it to have quite a few "rough edges".
Old Jun 18, 2013, 03:01 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
You may not have flown it by the end of June cp, but looking at it I am sure it will be structurally finished, which is all that is required for inclusion in the poll - don't forget to post a nice overall photo when you reach this stage so that I can "lift" it for use in the poll thread.
Sundancer is online now Find More Posts by Sundancer
Old Jun 21, 2013, 02:45 PM
cpmcgraw is offline
Joined Oct 2012
Progress Report
Upper hatch and windscreen now glued up. A little trimming, and mounting of the magnets, is all that's required here...
Old Jun 21, 2013, 03:02 PM
cpmcgraw is offline
Joined Oct 2012
Progress Report - Cont
Model now shown with upper hatch and windscreen fitted in place.
Old Jun 22, 2013, 01:16 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Almost ready to fling then!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jun 24, 2013, 08:46 PM
cpmcgraw is offline
Joined Oct 2012
Progress Report
Elevator hinges glued in. I'm going to remove the pushrods from the mix and hold them out until the radio is ready. All that is left to declare the model "mechanically finished" is the lower hatch.
Old Jun 25, 2013, 01:51 AM
Joined Nov 2008
Go for it, bwa!!!!
Old Jun 25, 2013, 05:50 PM
cpmcgraw is offline
Joined Oct 2012
I Hereby Declare The Envoy Mechanically Complete
There may be a few last pre-flight tweaks that are needed, but the construction of this model is finished. There is nothing left to build.
It's rough, it's not as pretty as I had hoped, and it most definitely took longer than I expected. But with a radio (and battery) installed, I would not hesitate to attempt a flight. That's my story and I'm sticking to it...
Photos 1-3 are the "official" final shots of the completed model, as requested by SD.
A couple of the items, like the LG and the hatches, will likely be re-built later for cosmetic appearances. But I'm still happy with how it turned out, as it represents my first attempt at an electric model, and I learned several construction and finishing techniques in the process. Equally important, I learned what not to do on future builds. I think that's just as important as what I learned to do.
Mamselle is on the back burner for now. The upcoming Build-Off looks like another great challenge, and I can't wait to get started.
I'm having fun! Really!
Old Jun 26, 2013, 12:49 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Looks great cp. Best of luck when it comes to the flying, but I shouldn't think you would have any problems. Congratulations on being the 20th completed model in the Build Off.
Old Jun 26, 2013, 01:35 AM
Joined Nov 2008
That looks great, Craig! And a really classy colour scheme - I may well unashamedly copy that sometime....
Fly-In SMALL 2013--May 30-June 2, 2013-Wrightsville, Arkansas Richard N Electric Flight Events 183 Oct 12, 2013 12:44 AM
Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Now 22 Finished Models! Sundancer Vintage & Old-Timer Designs 257 Jul 16, 2013 12:23 PM
Discussion Auster-Britplan Build-Off Jan 2013- Jun 2013 mrdj Vintage & Old-Timer Designs 6 Apr 02, 2013 06:02 AM
Discussion Proposed "Britplan Build Off" 2013 Sundancer Vintage & Old-Timer Designs 96 Dec 31, 2012 07:56 PM
Discussion A New Event January 2013 any interest? flyingdan1 Competition Aerobatics 3 Apr 20, 2012 07:14 PM
