Old May 25, 2014, 11:04 PM
moparren is offline
Find More Posts by moparren
I am what I teach
Tucson AZ
Joined Mar 2007
Centered the FC. Two good flights, on the third battery, no role right. Re-armed and it worked again.
The layout I chose is one of the three recommended in the instructions.
Originally Posted by 2dogrc View Post
Well,
Your FC450 is off center, that is an issue but would not cause the problems you are talking about.
I would try moving the 450 so it is centered, and then take your Receiver and mount it on top, way from the arms.
Let me know how that works.
Mark
moparren is offline Find More Posts by moparren
Old May 25, 2014, 11:40 PM
freqdrive is offline
Find More Posts by freqdrive
~Multitor Fanatic~
United States, NC, Kernersville
Joined May 2012
I have my 430 offset from center without issue
freqdrive is offline Find More Posts by freqdrive
Old May 26, 2014, 12:22 AM
moparren is offline
I am what I teach
Tucson AZ
Joined Mar 2007
Forgot to note - When I am doing these control checks the quad is not even in the air, I give it just enough to get the motors spinning and then check, so the FC is not seeing any movement yet, it's just not letting the signal through.
Old May 27, 2014, 05:14 AM
2dogrc is offline
Find More Posts by 2dogrc
2dogrc's Avatar
WHere Flight Was Born, North Carolina
Joined Apr 2005
I have sent this information to Dualsky because I have not seen anything like it. It sounds like some kind of connection issue since it is not consistent. But the question is where! Is in on the frame, receiver or internally on the FC!
Mark
2dogrc is offline Find More Posts by 2dogrc
Site Sponsor
Old May 27, 2014, 12:33 PM
moparren is offline
I am what I teach
Tucson AZ
Joined Mar 2007
Mark
I'm thinking along the same lines and this is my logic for thinking the FC may be bad - When I rearm it I don't pick it up, I just unplug and replug so there is minimal movement or vibration to shake a loose connector back into place. I doubt there is an issue with the arm-frame connection as the motors spool up with the throttle and react to rudder and pitch, so that connection seems to be working. In order to loose role control in one direction only means that two arms have to be affected simultaneously. I find it hard to believe that two parts are having identical random failures. If any of the wires between the FC, Rx, and frame were loose, I would have thought that would have been noticed when I moved the FC and Rx.
These are my thoughts.
Thanks for your help
Old May 29, 2014, 06:29 PM
~Multitor Fanatic~
Joined May 2012
2dog, Do you know when you will have the motors back in stock?
Old May 29, 2014, 07:15 PM
2dogrc is offline
2dogrc's Avatar
Joined Apr 2005
Not in this Dualsky order. Probably a couple weeks.
Site Sponsor
Old Jun 01, 2014, 11:33 AM
~Multitor Fanatic~
Joined May 2012
Ok, do you have the motor shaft only or know where I can get them?
Old Jun 02, 2014, 09:50 AM
2dogrc is offline
2dogrc's Avatar
Joined Apr 2005
Let me check, but I believe it is the ms2822 shafts.
Site Sponsor
Old Jun 02, 2014, 11:45 AM
2dogrc is offline
2dogrc's Avatar
Joined Apr 2005
We have a bunch of shafts. Ms2822
Site Sponsor
Old Jun 02, 2014, 06:52 PM
~Multitor Fanatic~
Joined May 2012
So just to be sure, the MS2822 is the direct replacement for the Hornet stock motors?
Sorry to nag you, I was looking under the Hornet parts and not replacement shafts
Old Jun 03, 2014, 04:25 AM
2dogrc is offline
2dogrc's Avatar
Joined Apr 2005
Okay.
The motors are 2830. We don't have any stock. It will be at least 2 weeks.
Site Sponsor
Old Jun 25, 2014, 09:30 AM
moparren is offline
I am what I teach
Tucson AZ
Joined Mar 2007
So, at what point do I give up and just take this thing back to the hobby shop? I've been grounded for a month now with no reply from Dualsky.
Props to 2dog for trying to get an answer but this is ridiculous.
Mark
Old Jun 25, 2014, 09:33 AM
~Multitor Fanatic~
Joined May 2012
Are those 2830 motor shafts in yet?
Old Jun 25, 2014, 10:19 PM
2dogrc is offline
2dogrc's Avatar
Joined Apr 2005
I am putting together another Dualsky order today and will see if I can get you a replacement FC. Which do you have the 430 or 450?
Site Sponsor
Sold $460 DA50 MTW canister new ring/piston/liner 16yr_old_flyr Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 17, 2012 02:28 PM
New Product Dualsky 460 Packs 2dogrc Batteries and Chargers 0 Dec 26, 2006 09:28 PM
Data New Motors ! 460 GT and 460 FX pete10844 Power Systems 1 Sep 06, 2006 07:37 AM
