Old Mar 23, 2015, 08:30 PM
pdooley is online now
Find More Posts by pdooley
You can call me Pat
United States, FL, Tampa
Joined Dec 2013
Jeff, I learned from the Century guys that suspect blade grip bearings can feel smooth sitting static but almost bind up under rotating force. You probably already know that but just throwing it out there..
pdooley is online now Find More Posts by pdooley
Old Mar 24, 2015, 01:05 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by Border Lord View Post
Hi AS
Thanks for that, useful info.
I am still not sure if it is the swash at fault. I have a new Garrt swash on the way, if that cures the problem, might go with the Helioption as a long term solution.
Looks like the small bearings that support the gimbal are user serviceable.
Would you know if the big one between the two sections is as well?
This model has flown so well with very little mods, I think it has earned itself a little bling.
Watch this space
Jeff
Swashplates with user serviceable bearings like the KDS and SAB ones have three screws in the bottom with heads that overlap the outside ring of the bearing and lock it in place and I don't see that on the Helioption swashplate.
I'm pretty sure an Agile5.5 / Innova 550/600 swashplate would fit though. You'd just have to replace the 5mm KDS balls with 4.7mm Align ones. As with the Innova and Agile tail grips the only difference between the swashplates seems to be the price, other than that they are the same part.
HK shows the old style Innova swash but they are actually shipping the new style one.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 24, 2015, 06:29 AM
Border Lord is offline
Find More Posts by Border Lord
South London United Kingdom
Joined Jun 2003
Hi All
Pat
Thanks for the tip. Can't detect any problems with the blade grips, but a possibility.
I do know I have play in the swash, so that would be my first port of call.
Currently got one on a row boat from China. Going to change that first see if it works before chasing anything else.
BTW, how's your 550 going, hint, hint!
AS
Thanks for all that info, but I have found a snag.
Looking at the specs, seems the Innova uses an 11mm mainshaft, where the HK550 is only 10mm.
Means the KDS one won't fit.
Good thought anyway.
Cheers
Jeff
Border Lord is offline Find More Posts by Border Lord
Old Mar 24, 2015, 09:16 PM
Joined Dec 2011
AS
Cheers
Jeff
According to the Innova 600 V2 manual the mainshaft bearings are 10x19x5 so I'm pretty sure that HK got that wrong. Unless the manual is wrong which I doubt (it is wrong about the size of the tail grip bearings which are listed as the wrong size in the diagram but the correct size in the parts list sidebar)
I have an Innova 700 which uses a 12mm mainshaft so I don't have an example handy to compare however I am 99% sure that the manual is right and HK is wrong.
Weird thing about the Innova 600 and 700 is that the one way hub and tail belt drive pulley is the same on both with the 600 having them ride on a 10x12mm sleeve and the 700 having the one way hub and pulley riding directly on the mainshaft.
Old Mar 24, 2015, 09:26 PM
You can call me Pat
Joined Dec 2013
Hi All
Pat
Jeff
All the pieces are in to get it done, but I have been flying the "other" 550 for now.
http://www.rcgroups.com/forums/showp...postcount=2046
I really would like to finish the HK550 to see how they compare though.
But then this is on the way too:
http://www.rcgroups.com/forums/showp...ostcount=15051
So the time frame for the HK550 is uncertain
Old Jul 01, 2015, 11:40 PM
You can call me Pat
Joined Dec 2013
ok, back at it for a few hours. one thing I didn't like about the HK kit was the puny looking ball links and rods. I replaced all of them with Align/Tarot. Interesting, the Align and Tarot link balls look identical, same physical dimensions and same markings. They look much better than the Gartt/HK stuff. The link rods are also thicker, 2mm as opposed to 1.6mm.
So the head is assembled with the new links and Align swash. My servo of choice is Turnigy BLS950's. They are MKS clones or re-brands. HK doesn't sell them anymore but they seem pretty good. For the price I paid on RCG classifieds I couldn't refuse. They are deeper than DS610's, so I had to use 2 servo spacers on each side to get clearance. I noticed the Aileron/pitch servo linkage rods are now angled to the swash; hopefully that doesn't hurt anything.
Just the tail setup left and some electronics and this thing should be flying.
Sold <<<SOLD>>> T-Rex 450 Pro HK Clone with da Blingggg $170 Mahu Aircraft - Electric - Helis (FS/W) 0 Apr 30, 2012 11:50 AM
For Sale perfect new tuned HK Pro GT TT /Trex 450 GT V3TT wupgrades & lipo 3D ready flys perf! blueindian Aircraft - Electric - Helis (FS/W) 0 Sep 12, 2011 01:00 AM
For Sale Hk 450 pro plus>>>>> my loss your gain lectroglide Aircraft - Electric - Helis (FS/W) 8 Apr 24, 2011 02:47 PM
For Sale Enclosed Trailer << $550.00>> obo huddle Aircraft - General - Miscellaneous (FS/W) 0 Aug 05, 2009 10:35 AM
For Sale JR 10X <<NeW>> $550 Shipped blueprints Aircraft - General - Radio Equipment (FS/W) 3 Jan 15, 2006 11:24 PM
