Old May 31, 2011, 12:19 AM
djsong121 is offline
Find More Posts by djsong121
Joined May 2011
Help!
Is this correct motor, ESC and batterysetup?
Hi,I am gonna build Oshkosh Special Thread Link.
I am gonna buy these all stuff for it please let me know is this correct for oshkosh plane.
1) Brushless Outrunner Motor 1800KV
KV : 1800
A (mm) : 3
B (mm) : 28.9
C (mm) : 28.9
D (mm) : 29.1
E (mm) : 63.9
Weight (g) : 47.6
Propeller (inch) : 6x4
ESC : 12A/15A
Voltage : 2-3S
2)20A ESC 2A Linear BEC
Type : Lipo
Weight : 20C
C : 40C
Burst : 2S
Cell : 1800
mAh : 14
H height (mm) : 32
W width (mm) : 103
L length (mm) : Gold Bullet 3.5mm
Connector : 91
3) 20C 7.4V 2S 1800mAh Lipo (Gold Bullet 3.5mm)
Type : Lipo
Weight : 20C
C : 40C
Burst : 2S
Cell : 1800
mAh : 14
H height (mm) : 32
W width (mm) : 103
Connector : 91
I mean with all thease that if I am not gona fry anything.
djsong121 is offline Find More Posts by djsong121
Old May 31, 2011, 05:09 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The motor and ESC will be perfectly happy with a 6x4 on only 2s... you could easily get away with 6x4 on 3s with an 1800Kv motor... and still be well under 20A. If an 8" prop fits, an 8x4 GWS HD on 2s would get you a lot more thrust than a 6x4.
I don't know the make of your motor but here are data pages for a comparably sized, ~1840Kv, KEDA TR2826/18:
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jun 01, 2011, 12:30 AM
Joined May 2011
Thanks Dr kiwi for your suggestion. I will buy a 8x4 proppeller. If any one can check too suggest me.
Old Jun 01, 2011, 06:27 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Sounds good mate. I'd also order some 8x6 nd 7x5props as well as you might want to switch around and see what works best. The 8x4 is a safe bet though.
Cheers - boingk
boingk is offline Find More Posts by boingk
Discussion Selecting correct Timing Degrees for Power 15 using EFLA 60 Amp Pro ESC VEGAS_RC_ACE Electric Warbirds 4 May 21, 2011 01:24 PM
Discussion OK, converted my nitro mustang with my new motor/esc is this a problem? cfiiman Electric Plane Talk 23 May 20, 2011 10:15 PM
Help! Correct Motor Offset and Incidence? James Frolik Modeling Science 2 Apr 26, 2011 03:11 PM
Question is this the correct way Doushiyou12 Power Systems 9 Mar 20, 2011 12:53 AM
Discussion could i use this motor with vxl esc? veggieslinger Off-road Cars 9 Mar 11, 2011 06:02 PM
