Old Oct 01, 2001, 08:29 AM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Hangar 9 Pizazz
Hi All,
My wife bought me a Hangar 9 Pizazz ARF as a gift, and I was wondering if anyone had any experience with converting it to e-power? TIA
Art Newland is online now Find More Posts by Art Newland
Old Oct 01, 2001, 09:25 AM
ezone
ezone
Guest
n/a Posts
Art,
I was looking at that one as well. Should make a nice conversion.
Jim
Old Oct 02, 2001, 02:34 PM
CD-ROM Junkie
Joined Apr 2001
Jim,
Do you think MEC turbo 10 plus on 10 cells would haul this around? APPROX 400 watts available. I haven't started to assemble it yet, but have weighed the components at about 3 1/4 pounds. Needs four servos and reciever as well. Looks like all up weight would be about 6 1/4 - 61/2 lbs. TIA
Old Oct 02, 2001, 03:05 PM
Neil Morse is online now
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
A guy who flies at one of the local fields has one powered by one of the Jeti brushless motors. It flies really well. Sorry, I don't have the details.
Neil
Neil Morse is online now Find More Posts by Neil Morse
Old Oct 02, 2001, 03:20 PM
ezone
ezone
Guest
n/a Posts
Art,
I was planning to use 16 cells.
10 cells will work because the plane is very light for its size.
Jim
Old Oct 02, 2001, 03:25 PM
aft_cg is offline
Find More Posts by aft_cg
aft_cg's Avatar
Baton Rouge, LA
Joined Jun 2001
The hot-dog pilot at my field has a Pizzaz, but it is powered by a .81 4 stroke. I know this dosn't help your decision but it is an awesome flyer. Any stunt you can think of and then some. I also don't have a weight on that setup but it is a very good flyer.
aft_cg is offline Find More Posts by aft_cg
Old Oct 02, 2001, 05:54 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Thanks to Fred Bronk, I have a similar plane on the way. I just bought a Dazzler from him and I plan on using 16 cells, a 10x7 prop, and a Jeti 40 brushless. If I can't afford that, I'm going to try the GWRIGHT combo on an Endo, 4.6:1 GB, 12x8 prop, and 10 cells. Either way, when I build the kit, I'm going to replace some of the heavier wood and make lightening holes where I can.
dave_lilley is offline Find More Posts by dave_lilley
Old Oct 03, 2001, 02:31 PM
CD-ROM Junkie
Joined Apr 2001
FYI,
The wing is built all it one piece and inserted through the fuse. There is not a lot of room inside the fuse because of this. Getting more than ten cells into the area where the fuel tank goes is going to be pretty difficult. Looks like a 10 cell sub C size pack will fit into this area lying diagonal from bottom of the firewall and over the top of the wing. I have decided to go the turbo 10 route with 10 cells and will post the results on ezone when it's completed. Wish me luck! Thanks, Art
Old Oct 03, 2001, 02:43 PM
Texas
Joined Aug 1999
Check out the Dazzler review. The writer removed the sheeting from the LE of the main wing to make more room for the batteries. You may be able to do something similar, if you are interested.
Hangar 9 Pizazz New in Box mmm208 Aircraft - Fuel - Airplanes (FS/W) 1 Dec 14, 2004 07:53 AM
Hangar 9 Pizazz for sale MHawker Aircraft - Fuel - Airplanes (FS/W) 5 Jan 02, 2004 04:18 PM
FS/FT: Hangar 9 Pizazz - pikup or meet. FlightofSong Aircraft - Electric - Airplanes (FS/W) 2 Jun 09, 2003 08:23 PM
Question Hangar 9 Pizazz 40 tame or toucheeee Dan and son Bry Fuel Plane Talk 0 Jul 09, 2002 11:04 PM
