Old Jun 25, 2014, 12:19 PM
peterswolf's Avatar
United States, FL, St Petersburg
Joined Apr 2012
Originally Posted by propchief View Post
My tailwheel fell off and I just put a piece of plastic tube (yellow nyrod) back there to keep the tail raised. One thing it eliminates is the rudder and tailwheel misalignment and fighting each other.
Ya I wish there was more space inside the fuse, I would mount a separate servo for the tailwheel and run it on its own channel...
peterswolf is offline Find More Posts by peterswolf
Old Jun 25, 2014, 12:22 PM
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
I think it is a geometry issue. I will one of these days fix my gear forward to see if that helps. I currently finished most of my projects.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Jun 27, 2014, 06:50 AM
Belgium, Flemish Region, Geel
Joined Jun 2013
Originally Posted by peterswolf View Post
I might throw some washers on the inside screws of the struts and see if I can widen the stance a little bit and straighten it out. Perhaps that may help some of the ground control.
It helps a lot. I added some fairly thick plastic prop centering rings/adapters on the inside of the landing gear mounts, and now they are parallel and I regularly/usually manage to land without wing tip scraping .
Vertigo72 is offline Find More Posts by Vertigo72
Old Sep 07, 2014, 11:39 AM
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I had crashed mine really hard this spring, and thought it was not recoverable. I even went as far as to remove the servos from the (broken) wings, and used them elsewhere. I recently revisited the wreckage, and have fixed it. I should maiden (re-maiden?) by next weekend. I may do a repaint also, just to have something different. I miss this speed demon. -------Metalguy
metalguy is offline Find More Posts by metalguy
Old Sep 07, 2014, 12:33 PM
Joined Jul 2011
Go for it Metal. I went to fly mine this morning after a few months break and when I got to the field I realized I had taken the BEC out to put in another plane. Oh well. She does fly different from all the others.
Old Sep 08, 2014, 01:13 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I hate it when I do stuff like that! I let a friend borrow a "y" harness out of my Spitty, and forgot to get it back. No flying for it that day either! ----Metalguy
Old Sep 09, 2014, 03:56 AM
Joined Jun 2013
Originally Posted by quitcherbitchen View Post
Go for it Metal. I went to fly mine this morning after a few months break and when I got to the field I realized I had taken the BEC out to put in another plane. .
Out of curiosity, how do you connect the BEC so that its removable?
Old Sep 09, 2014, 10:01 AM
Joined Jul 2011
I always use JRT plugs on the Bec's power side. That way I can move them around or take them off if I sell the plane. So you need to buy JRT plugs to solder into your ESC. I actually crimp mine as I use Anderson power poles.
Old Sep 09, 2014, 06:57 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Never thought of making the BEC removable. I just solder them in place. -----Metalguy
Old Sep 13, 2014, 09:27 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Well, I think she is ready for a re-maiden now. I replaced all the servos I stole out of it for other projects after I thought I wasn't going to fix it, and made new linkages, as well. I had to piece in some Vampire parts to fill in where some foam was lost, so its not pretty any more, but should fly just fine. Besides, once in the air, it should look fine! ------Metalguy
Old Sep 14, 2014, 08:47 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Flew her twice today. Not as fast as i remember, but I was trying to keep up with a Mosquito, and a T-28. Still flies very nice! -------Metalguy
Old Nov 03, 2014, 11:46 AM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I got in some flying in the wet November weather yesterday, between cloudburst, and against the grey sky, this camo really works! This plane is awesome to see fly. It can slow right down, and just seem to hang there, or clean up the flaps, and be off to the races! I have my ailerons turned way up on the throws, and she performs pretty well! ----Metalguy
Old Nov 04, 2014, 04:28 AM
hover, glide, fly
Vortex000111's Avatar
Australia
Joined Mar 2012
hey metalguy, i agree this plane looks awesome, I've had onlookers compliment me on it... that's when i explain it was a kit and not my modeling skills ... but nonetheless it is a beautiful sight. great to hear about the flight, mine should be up soon but end of year exams have put mine in the hanger for now.
Vortex
Vortex000111 is offline Find More Posts by Vortex000111
Old Dec 14, 2014, 12:33 PM
Joined Jul 2011
Flew mine yesterday and had a blast--litterally. Dropped the Adam Bomb from different altitudes, but 50' seem the most accurate. The Adam Bombs are in stock at DymondUSA https://dymondusa.com/ in case you need to get one for yourself and turn this plane into a D-5 model. Super easy if you have a computer radio that sets end point adjustment and with a standard 6 channel you can have so much more fun with this model. Check my blog for directions in mounting.
Build Log Junkers Ju-87 Stuka - 100" - Nick Ziroli flyer77 Serbia 111 Nov 18, 2014 07:49 AM
Discussion Don't buy the Airfield JU 87 Stuka from Nitroplanes! rotorblade400 Foamies (Kits) 9 May 26, 2012 05:14 AM
For Sale USD144.9 NIB FMS 1400mm JU-87 Stuka Electric Warbird PNP www.hobbyb.com Aircraft - Electric - Airplanes (FS/W) 1 Apr 19, 2012 09:35 AM
Sold TX LPU: 1400mm JU-87 Stuka Dive Bomber, PNP Roswalt Aircraft - Electric - Airplanes (FS/W) 9 Apr 12, 2012 02:12 PM
Sold TX LPU: Reduced Price 1400mm JU-87 Stuka Dive Bomber, PNP Roswalt Aircraft - Electric - Airplanes (FS/W) 1 Apr 12, 2012 02:12 PM
