Old Feb 10, 2005, 12:52 AM
San Carlos, California, United States
Joined May 2002
Slotted vs Slotless motors - advantages?
I've been looking around the web looking for comparisons of slotted vs. slotless motors. Unfortunately, it mostly turns up searches of motor companies touting the advantages of their slotless motor technology.
The only webpage I could find which would even mention a few of the advantages of slotted motors was:
http://www.designnews.com/article/CA87122.html
As I understand so far:
Advantages of slotted motors:
o More powerful (more torque) due to smaller air gap between iron and magnets
Advantages of slotless motors:
o No cogging
o Larger rotor size
o Reduced damping losses due to eddy currents
If anybody has more info, could they post? Also, I'm interested in efficiency comparisons at partial throttle for slotless vs. slotted motors.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 10, 2005, 01:15 AM
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
For our application whether a motor has cogging or not is neither an advantage or a disadvantage. For some precision applications it does.
As for partial throttle efficiency the biggest factor here is the design of the controller not whether a motor has slots or not. The controllers that are presently on the market for us could be improved a lot as far as part throttle efficiency goes.
Quiet Flyer Magazine a while back had comparisons of different controllers at part throttle in the PowerOn column.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Old Feb 10, 2005, 01:39 AM
Joined May 2002
Chuck
The cogging isn't a disadvantage for R/C planes, but it's a disadvantage for R/C cars. There are a few car forums here.
Toshi
Old Feb 10, 2005, 03:16 AM
Joined Sep 2003
1 disadvantage with strong cogging motors shows up when used with the smaller and lower C batterys: When the throttle is slowly advanced from zero, the motor dosn't turn untill the starting current is reached. Then the motor runs fast because the no load current is lower than the starting current. During the time the throttle is being slowly advanced and the motor is not turning, the current is very high and can exceed the C rating. I= (batt volts -bemf)/r .
GB
Plantoflap is online now Find More Posts by Plantoflap
Old Feb 10, 2005, 08:49 AM
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
True, but this topic is posted in the "Airplanes - Electric" forum.
Cogging in a slotted motor depends a lot on the rotor design. So, if cogging is a major issue for your application, you can minimize it by changing the rotor. Magnet width, magnet strength and air gap are primary factors.
-David
davidfee is offline Find More Posts by davidfee
Old Feb 10, 2005, 12:18 PM
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
There are very good slotless and slotted motors, and there are not so good of each type as well.
Kontronic, hacker, and lehnor are examples of very high quality slotless.
Aveox, plettenburg, neumotor, and acro (outrunner) are examples of high-end slotted.
The only real difference from a pragmatic standpoint is that slotted motors tend to have lower kvs, so they need lower ratio gearboxes than slotless. All Direct drive motors (inrunner or outrunner) are slotted because slotless do not have enough torque to runn dd except in ducted fans.
Just for fun, look up kontronic "tango" motors. These motors are sort of in between slotted and slottless, as they have a unique rotating iron ring to reduce iron losses. These motors are ridiculously efficient, really nice if you want a motor in the 800-1400 watt category.
twest is offline Find More Posts by twest
Old Feb 11, 2005, 01:39 AM
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
Toshi
Yes, I was commenting as regard to use in airplanes since that is what this forum is about.
Why is cogging not good for cars?
Chuck
Old Feb 11, 2005, 02:33 AM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Chuck
It acts like a break... when you come of the throttle you want some free wheeling any breaking should come from the speed controller so that you have better controll over it..
PaulVi is offline Find More Posts by PaulVi
Old Feb 11, 2005, 05:23 AM
Joined May 2002
I was thinking about this earlier.
It seems slotted motors are better for low Kv/high torque applications, and slotless are better for high Kv/low torque.
I'm primarily interested in helicopters, actually, and in most helicopters we run motors at around 20k-24k RPM. Many people use slotless motors (Hackers and Kontroniks), but these motors seem like very poor choices for this RPM range.
It seems like below 30k RPM, slotted is better due to more torque, but above 30k RPM, slotless is better because of lower losses due to not having an iron core.
Toshi
Old Feb 11, 2005, 09:48 AM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Once the motor is spinning the drag is the same for both types.
Steve
sneu is offline Find More Posts by sneu
Old Feb 11, 2005, 09:54 AM
sneu's Avatar
Joined Dec 1999
Toshi
Not really right--there are many issues that go into the designs and the details really determine how a motor will perform. Both motor types can work well at the same RPM ranges if designed for the application. Slotted motors can and do run at very high RPM--as do slotless motors. In most cases the stator materials and rotor design really determine the suitablity for high RPM.
Steve
Old Sep 20, 2014, 10:35 PM
Joined Jul 2014
I imagine since I want to make a slotless inrunner with something like 100kv it'd need to have many poles on the rotor and the rotor would also need to be wide. How would the windings be different with the intention of a low kv high torque inrunner? I imagine the winding poles would need to also increase and the wire thin. And then a flux ring or back steel behind the windings.
If electrical steel were ground to a powder or filings and mixed with epoxy and reformed would it still keep it's desirable electrical properties?
Hummina is online now Find More Posts by Hummina
Old Sep 21, 2014, 03:17 AM
Staffs, UK
Joined Nov 2003
Rather than resurrecting this almost 10-year old thread you'd probably do better with your queries in the Electric Motor Design and Construction forum http://www.rcgroups.com/electric-mot...struction-361/
Steve
slipstick is online now Find More Posts by slipstick
Graupner Speed 400 vs. Zagi motors Clu Electric Plane Talk 16 Feb 09, 2002 10:09 PM
Conventional vs coreless motors jeb122 Beginner Training Area (Aircraft-Electric) 6 Jan 22, 2002 04:47 AM
Sensorless vs sensor motors crobinett Electric Sailplanes 3 Dec 28, 2001 01:50 PM
A question about coreless vs. brusless motors Clu Power Systems 1 Dec 27, 2001 04:02 PM
Brushless vs. Brushed motors - share the love! Andy W Electric Plane Talk 27 Dec 24, 2001 04:51 PM
