Old Jun 16, 2013, 10:49 AM
United States, CO, Colorado Springs
Joined Jul 2004
Motor question
What does 35T translate to on the ground apposed to a higher turn motor.
I'm looking for decent scale speed and offroading what turn motor should i get.
smoothb10 is offline Find More Posts by smoothb10
Old Jun 18, 2013, 10:32 AM
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
A 35T motor would be fine for a scale truck. If you go up in turns, you will gain more torque and lose top speed.
Paul Onorato is offline Find More Posts by Paul Onorato
Old Jul 08, 2013, 04:51 AM
cconwell21
United States, IN, Anderson
Joined Mar 2013
motor
I found the 27 turn to be effecient.
cconwell21 is offline Find More Posts by cconwell21
Old Jul 09, 2013, 06:36 AM
oh that guy
United States, SC, Clover
Joined Sep 2012
Most scaler guys run between 27t and 35t. More leaning to th 35t end.
slim_chance is online now Find More Posts by slim_chance
Old Jul 11, 2013, 07:50 AM
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
there is more to it than just the motor turns. you would also need to look at the gearing (pinion and spur), the overall truck weight, and the type of motor your buying. not all motors are created equal.
just as an example you could get a holmes hobbies 35t torquemaster and have good speed and crawl pretty well, or you could use a 16t crawlmaster and get even better crawling and more speed.
on the other hand, you could run a 35t and gear it down where it's slow but crawls very well, or gear it up and it will be very fast but not crawl very well.
the higher the gearing usually the hotter the motor will run. what truck are you putting the motor in??
hoghead5150 is offline Find More Posts by hoghead5150
Question Question regarding very large motors helifrek Electric Motor Design and Construction 16 Apr 08, 2013 06:51 PM
Question Basic motor questions Greiswig Multirotor Electronics 16 Apr 04, 2013 09:57 PM
Discussion Help - Question on hacker motor and prop assembly WHOOOOOOOSH!! Electric Plane Talk 2 Mar 30, 2013 08:50 PM
Help! Motor Spec Question williamjames Electric Motor Design and Construction 4 Mar 29, 2013 04:06 PM
Discussion Question about the Brushless 2226/2300 KV Easysky motor question (dolphin/cessna) twincobra Micro Ready-to-Fly 0 Feb 11, 2013 12:49 AM
