Old Jan 26, 2003, 06:20 PM
tenover is offline
Find More Posts by tenover
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Homemade Y-Harness?
How difficult is it to make a Y-harness so that I can mix the ailerons into a single channel? I have all kinds of servo leads and connectors I can use, just not sure about how (or IF) I can wire them up...??
Thanks!
tenover is offline Find More Posts by tenover
Old Jan 26, 2003, 07:34 PM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Its pretty easy if you can solder. Take two female servo leads(ie charge sockets) and one male servo lead(like what comes out of a servo), and join the appropriate colours together, ie all reds to reds, all browns to browns and all oranges to oranges. Make sure none of the joins can touch the other exposed joins, hot glues is good for insulating them, and you're set.
(this assumes all leads are standard factory colour codes and have not been modified or reconfigured)
Good luck
Adam
Foxy is offline Find More Posts by Foxy
Old Jan 26, 2003, 08:59 PM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Thanks Adam,
I'll give it a shot tonight after THE game....
Shortening Servo Leads and Y Harness questions... flipnidaho Electric Plane Talk 5 May 09, 2003 12:30 PM
Help! HELP, Aileron Y harness causing rudder to glitch!!! T-Bo Radios 6 Jan 20, 2003 04:01 PM
Y harness tow hook Skid Electric Sailplanes 2 Feb 05, 2002 10:20 PM
Flaperons vs. Y harness Van Electric Plane Talk 2 Jan 09, 2002 09:40 AM
Y harness/Epoxy rob dahlbo Beginner Training Area (Aircraft-Electric) 2 Dec 01, 2001 05:39 PM
