Old Jul 09, 2007, 08:20 AM
beezee2 is offline
Find More Posts by beezee2
Des Moines, Iowa
Joined Jul 2007
Help!
Outrunner spontaneously reversed!
A friend had a funny thing happen... His kit-built outrunner motor reversed direction since the last flying session. He said he had recently smacked it into the ground.. Anyone have any idea what's going on with his motor?... I may ask him to bring his plane over to my shop so we can trouble shoot by switch out components...
beezee2 is offline Find More Posts by beezee2
Old Jul 09, 2007, 08:22 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
Switched (any) two of the tree leads between motor and controller?
Changed direction in controller setup?
Vriednelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 09, 2007, 08:28 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
Actually that happened to me recently, using a 400XT on a cheapo Robotbirds Chinese 18A speed controller. It actually happened between one flight and the next, all I had done was change battery.
There's no documented reverse mode in the speed controller, but I assume it must have been there somewhere in the firmware, and triggered itself through a software error of some sort. Tried every way I could think of to reset it but ended up just changing over two of the ESC to motor leads. That done, flying continued as normal and I haven't had to change it again.
Work in Progress is offline Find More Posts by Work in Progress
Old Jul 09, 2007, 09:51 AM
beezee2 is offline
Des Moines, Iowa
Joined Jul 2007
Thanks guys... I'll likely switch the wires around and that should take care of it.
Old Jul 12, 2007, 09:33 PM
Frank Rothmann is offline
Find More Posts by Frank Rothmann
Anderson, SC
Joined Jan 2005
Could the magnets have reversed polarity by being shocked in the crash ??
Frank
Frank Rothmann is offline Find More Posts by Frank Rothmann
Old Jul 13, 2007, 07:12 AM
BeavrdamElectric is offline
Find More Posts by BeavrdamElectric
Beaverdam Creek, VA
Joined Aug 2005
Frank
If all the magnets reversed it would still run the same way. If some of them reversed it would run poorly if at all. I don't think shock can reverse magnetic polarity though. Most likely the ESC.
Good Luck!
BeavrdamElectric is offline Find More Posts by BeavrdamElectric
