Old Feb 21, 2015, 02:27 PM
stephavee is offline
Find More Posts by stephavee
Twin screw homebrew
stephavee's Avatar
Joined Nov 2011
Dumas deck fittings?
I have been reading and from what I can tell Dumas's deck fittings are a plated alloy of some sort. I have been reading that people in the past have sanded and filed these parts to make fix the lack luster quality that they come in. My question is did Dumas change the material these are cast in? because when I sanded and filed my to a smooth finish I did not find the yellow-ish colored alloy that many others found. Instead mine are bright and when polished look great! Did I just get lucky or am I mistaken?
stephavee is offline Find More Posts by stephavee
Old Feb 21, 2015, 02:46 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Wow, that really looks good stephavee. I'm wondering how that shine will hold up over time particularly in a wet environment. I too was disappointed with the fittings that came with my Typhoon. Think I'll have to revisit the kit and try polishing it's fittings. Thanks.
babblefish is offline Find More Posts by babblefish
Old Feb 21, 2015, 03:26 PM
Twin screw homebrew
stephavee's Avatar
Joined Nov 2011
I think its cast aluminum...If im right it should hold up well with periodic buffing. I wish I had a before picture! In my mind these fittings should come looking a lot better!
Old Feb 21, 2015, 03:47 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
Dumas still cast their parts the way they always have, it is just that you may have gotten a set that was not plated. After they cast their parts they are sent out for barrel plating which consists of first plating with copper than with chrome. If anyone wishes to polish their deck fitting that are in the kit, call Dumas and ask to exchange the plated parts for un-plated parts which you can then polish up.
Un-plated Dumas fittings which have been polished up can be made to look like chrome. Remember to top coat the fittings with a clear coat to prevent tarnishing of the finish on the part. Also I now use the MACK attachment tape for installing hardware on finished decks to prevent gluing screw-upís.
frankg is offline Find More Posts by frankg
Old Feb 23, 2015, 07:18 AM
oldnavy is offline
Find More Posts by oldnavy
I need to try this. I have my typhoon shelved because I'm so disappointed with the quality of the cast fittings.
oldnavy is offline Find More Posts by oldnavy
Old Feb 23, 2015, 09:23 AM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
I did this with my Dumas Triple. Dumas was very quick in replacing the plated parts with unplated.
oldtribefan is offline Find More Posts by oldtribefan
Discussion 3D Printing Metal Parts & Shiny Deck Fittings patmat2350 Scale Boats 30 Nov 16, 2014 08:43 AM
Discussion Old dumas equation deck install help darticus Sailboats 3 May 03, 2014 01:43 AM
Question Polishing old deck fittings. Building One Dock Talk 15 Feb 05, 2014 08:32 AM
Discussion Deck fittings Ronin055 Sailboats 13 Jan 11, 2014 01:50 PM
Question Dumas USS Whitehall deck fittings crazygary Scale Boats 3 May 03, 2013 07:59 PM
