Old Feb 21, 2015, 05:35 PM
KiwiKid is offline
Find More Posts by KiwiKid
Keep calm and don't blink
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Originally Posted by WOO WHO View Post
Hi Billy,Sorry for the late reply.But I only just looked at this thread.
Woo, if you subscribe to your own thread you will get an e-mail when someone posts on it (if that's what you want).
KiwiKid is offline Find More Posts by KiwiKid
Latest blog entry: The Phantom Menace
Old Feb 24, 2015, 12:37 PM
rc hang glide is offline
Find More Posts by rc hang glide
rc hang glide's Avatar
United States, OH, Marion
Joined Feb 2015
hello WOO WHO thank you.. understand your busy I asked for some specks on your hang glider build really need some of your help here on this sincerely thank you, for the help on my attempt to build the hang glider WOO WHO I asked 3 question to help me start waiting to here from you thank you,,,,,,
rc hang glide is offline Find More Posts by rc hang glide
Old Mar 15, 2015, 01:11 AM
Joined Feb 2015
my version confused: an by no standards do I think this compares to his MASTER hang glider.. I must say after building the R.C. frankinhang glider, haha I made too heads one with helmet an other one face with goggles i cant wait to test it off a nice cliff to bad there is none in ohio like the awesome New Zealand.. I posted a few photos of the frankinhang glider built still under way...
Old Mar 15, 2015, 04:15 AM
WOO WHO is offline
Find More Posts by WOO WHO
New Zealand, Wellington, Wellington City
Joined May 2012
That's great Billy,well done love to see your hang glider fly.
Please keep us up to date with progress.
Woo
WOO WHO is offline Find More Posts by WOO WHO
Old Mar 15, 2015, 07:59 PM
Joined Feb 2015
woo who thanks sorry to say I powered it up today an I dose not move the wing proper I need help I've been guessing at every thing looks as if I guessed rong! sad lots effort on my part A = EFFORT F =failed V.S.= very sad....................... Woo Who if you could please help on some tips about the hang strap an whats it made of ?? understand its a ridig wire out of pilots lower back,,but whats the wire connected to ?? an how do you keep it connected to the keel an stay ridig ?? thank you
Old Mar 15, 2015, 10:33 PM
rrcdoug is offline
Find More Posts by rrcdoug
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
RC Hanglide - I am impressed with your model. Don't give up yet.
I believe you are shifting the pilot for pitch control. This may be too little as full size hang gliders weigh about half of pilot weight. This might mean you have to use the ailerons as elevons as well as shiftng the pilot weight.
I see ailerons. This is good. People will tell you that hang gliders don't have ailerons and they turn when the pilot shifts his weight sideways. What the don't mention is that when the pilot shifts his weight, the sail shifts too and twists so that hang gliders roll by wing warping. Ailerons are just another form of wing warping.
I guess you have the reciever and battery in the pilot so you must run wiring up the hangstrap to run the aileron servos. If you use an elevon mix on the ailerons, you will need 2 channels and 2 servos. The elevons or ailerons will have to be reflexed to create some pitch stability.
Test fly in a forgiving setting, long grass and gentle slope. You will probably have difficulty finding a stable pilot hang point so you need to have a forgiving setting. Maybe snow would be more likely than long grass right now.
rrcdoug is offline Find More Posts by rrcdoug
Old Mar 15, 2015, 11:38 PM
Joined Feb 2015
thanks rrcdoug Im using the servos in the body to have pitch an ailerons for left right but now that its not working as I had to guess im no model builder I just gave it my best try I wanted a hang glider like Woo Who's so bad I do anything. but failed trying ... I will try to like you said no longer use servos in arms an just use elevator ailerons mix for all control an just make the pilot stiff like dead stiff maybe it might help......... ok powered it up just now I tried holding the body in one hand an used the stick in my other hand and the hang glider and works proper while I hold the pilot stiff an the arm push the control bar up down right left >?? now Im really lost on what to do,,hmm help !
Old Mar 16, 2015, 10:36 PM
Joined Feb 2015
That's great Billy,well done love to see your hang glider fly. thanks woo who' i would to
Woo
hard work did not pay off in my case
Old Mar 16, 2015, 10:57 PM
rrcdoug is offline
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
RC Hanglide , when you write that it doesn't work, are you referring to pitch or the ailerons?
If pitch not working... maybe your control bar position is incorrect. This depends on the hangstrap fastening position on the glider which depends on the desired CG of the glider (including the "pilot").
Considerring this messy situation, it might be a good idea to switch to elevon control with a fixed CG as a temporary test phase. This will allow you to adjust the pilot position to change the CG. Once you are satisfied with the pilot postion and settled on a hangstrap location, you could adjust the control bar (A frame) so that the pilot's arms have the ability to shift the pilot both forward for speed and back fore flaring. Warning: flaring probably won't work at this scale and your airfoil.
Remember, this is a flying wing, so it needs reflex in the elevons or washout with sweep to give it pitch stability.
Old Mar 17, 2015, 01:53 AM
WOO WHO is offline
Joined May 2012
I second that! Doug is bang on.(more sweep)
Old Mar 18, 2015, 01:14 PM
Joined Feb 2015
thanks rrcdoug woo who made comment but of course I don't understand it but none the less this was way above what I know how to do! thanks for your time
thanks to the guys that respond with there help! tried!
Old Mar 19, 2015, 07:10 PM
rrcdoug is offline
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
Sweep would be good, but not really an option for your already built wing. It may still work for you with enough reflex in the ailerons. I think your wing was already a flying wing but I believe the pilot drag below the wing is a destabilizing influence because it would increase quite a bit at speed pulling the nose down. This is only a guess. Don't give up too easily, I think it could be trimmed.
The reflex, and/or sweep with washout, creates a nose up tendency with increased speed so the aircraft will seek a trim speed. This function is normally prvided by the horizontal stabilizer (tailplane).
Old Mar 28, 2015, 08:22 PM
Joined Feb 2015
update still working with this . new photos ready to try a maiden its got great C.G. so I hopeing that will be on my side , found a new unused Robbe SkyFlex 2000 a awesome guy in Germany..
Sold Vintage R/C Hang Glider / Ultralight Kit NIB! Very Rare! arp67 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 04:29 PM
Sold Vintage R/C Hang Glider Kit NIB! Very Rare! arp67 Aircraft - Sailplanes (FS/W) 0 Feb 20, 2011 12:49 PM
Discussion R/C Hang Glider Project - Elevon Question arp67 Flying Wings 3 Jan 09, 2009 10:12 AM
Discussion R/C Hang Glider Project - Elevon Question arp67 Slope 7 Jan 08, 2009 08:22 PM
