Old Jan 21, 2004, 12:40 PM
Endor is offline
Find More Posts by Endor
Endor's Avatar
La Mirada, CA
Joined Dec 2003
Formosa motor mounting - 300 vs 400
Hi folks,
I have a Himax 2025-5300 coming for my Formosa. I bought a combo unit from e-Flightline since it seems like such a good deal... basically the motor, GWS-400 gearbox, their hardened Cobri shaft, prop adapater, CC Phoenix 25, and all the necessary connectors.
I currently have the stock 350c (and hence a 300-series gearbox). I have the wood mounting stick in the top fuselage mounting hole, so the motor "hangs" off the stick.
The manual says to put the stick in the bottom hole if running the EPS-400, which means the motor "sits" on the stick.
I assume that this is to properly line up the prop shaft with the cowling, but having not seen a 400 gearbox close-up I'm just guessing.
Could anybody who has a similar setup comment on how they have their 400 gearbox mounting in their Formosa? I really hope I don't have to move that stick, 'cuz I had to epoxy it like crazy to fix the mount after a "mishap" dislodged it. Thanks!
Endor is offline Find More Posts by Endor
Old Jan 21, 2004, 08:21 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
My eps 400 slid right on in place of the 350. Everything lined right up, no problem.
The biggest problem with the swap was compensating for the extra nose weight. I had to slide my 8 cell 950 kan pack WAY back.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Jan 21, 2004, 09:56 PM
Endor is offline
Endor's Avatar
La Mirada, CA
Joined Dec 2003
Thanks for the reply Dean, that's what I was hoping to hear!
Old Jan 22, 2004, 03:03 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
The are are two types of GWS Speed 400 motors. The EPS-400 Motor/Gearbox and the EDP-400 Direct Drive Motor.
The EPS motor/gearbox goes on the top position and the EDP direct drive goes on the battom position.
Ken
kensp is offline Find More Posts by kensp
Old Jan 22, 2004, 05:13 PM
Endor is offline
Endor's Avatar
La Mirada, CA
Joined Dec 2003
Aha!
I must have misread the acronym... that makes sense, thanks for clearing that up for me guys!
The GWS 300 vs 350 Motor Tuffbird72 Power Systems 35 Jun 24, 2004 12:02 PM
EPS 300 and EPS 400 motor mounting screws? HankF GWS (Grand Wing Servo) 3 Jan 15, 2004 01:04 PM
Razor 300 vs 400 bcripe1 Power Systems 10 Jul 19, 2003 12:10 PM
Motor comparison GWS Vs 280, 300, 400? Dodo Bird Foamies (Kits) 1 May 14, 2003 12:01 PM
speed 300 vs speed 400??? shadetreeflyer Electric Plane Talk 4 Feb 24, 2002 07:57 AM
