Old Mar 31, 2015, 06:40 AM
Larry1962 is offline
Find More Posts by Larry1962
Joined Mar 2015
Hello everyone
I purchased the unit s2 version to install on a 450 waiting to put it in the fuselage. I wanted the unit to further stabilize the eli since I mount a four-blade rotor. Well I have already destroyed a rotor for excessive speed of rotation of the blades in an attempt to find the best values for that type of flight. Is there someone who uses it on a reproduction? Which settings take?
Thank you.
Larry1962 is offline Find More Posts by Larry1962
Old Mar 31, 2015, 01:53 PM
GadgetMart is offline
Find More Posts by GadgetMart
United Kingdom, England, Manchester
Joined Jan 2013
I have also just purchased a S2.
I have bound it with a Spektrum satellite and all seems good in DSMX mode.
(I have had to set the Tarot to DSMJ to achieve this).
I intend to fit it to a Tarot 450 Pro helicopter, does anyone have any PID settings for the S2?
Thanks.
GadgetMart is offline Find More Posts by GadgetMart
Old Apr 06, 2015, 02:57 AM
2Doggs is offline
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Presets!
Before you mess with PID settings, just fly the heli with the preset models and see which one you like best. With the original ZYX, most folks left cyclic PID's at default and only changed the tail.
2Doggs is offline Find More Posts by 2Doggs
Old Apr 06, 2015, 08:18 PM
jerseysgt is offline
Find More Posts by jerseysgt
jerseysgt's Avatar
Joined Nov 2014
The S2 doesn't give you the preset options like the earlier versions. Don't understand why they omitted them.
jerseysgt is offline Find More Posts by jerseysgt
Old Apr 08, 2015, 03:37 AM
2Doggs is offline
2Doggs's Avatar
Joined Nov 2009
Wow, that seems like a really retrograde step! You could use them to do all your initial checks and then start hotting things up to your liking.
Old Apr 08, 2015, 06:39 AM
lcc014 is offline
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
S2 does give you preset options but it is only Default or 3D Flight. It is located on lower right hand corner of the Main screen called "Pre-Set Parameters". Definitely not like zyx-s PC software which provides several preset options similar to vbar.
lcc014 is offline Find More Posts by lcc014
Old Apr 08, 2015, 05:03 PM
jerseysgt's Avatar
Joined Nov 2014
I chose the 3D option and tried toning it down to where I could handle things. I just wish they would have left in all the presets from the earlier versions.
Old Apr 08, 2015, 06:30 PM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
I have the same wishes too
Old Apr 19, 2015, 03:57 PM
grasschopper is offline
Find More Posts by grasschopper
bluefield va.
Joined Sep 2009
Hi guys could someone please help me find a diagram or vid on how to connect a zyx-s to a futaba 617 rx.........Ive got the software down loaded just wanted to see how the wires connect....I hooked up zyx a few years ago but now Ive forgotten how to...Thanks Chopper......
grasschopper is offline Find More Posts by grasschopper
Old Apr 19, 2015, 08:37 PM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Have you checked the very first post of this thread ?
Old Apr 19, 2015, 09:20 PM
bluefield va.
Joined Sep 2009
Yes sir I've been looking just haven't found what Im looking for yet but Ill keep trying....
Old Apr 19, 2015, 09:45 PM
bluefield va.
Joined Sep 2009
Ok finally found wiring diagram....Thanks
Old Yesterday, 06:33 AM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Good to know.
Old Yesterday, 08:30 PM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
The ZYX-S2 is a completely different unit than the ZYX-2 with different software. They basically started over from scratch with it. I have no idea why they didn't just port the old firmware to the new hardware though. Maybe it was a bunch of spaghetti code and the original programmer had left?
Atomic Skull is online now Find More Posts by Atomic Skull
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
