Old Jun 14, 2009, 06:40 AM
b727-77 is offline
Find More Posts by b727-77
Joined Jul 2008
Boeing 727-100 Gws-50 Edf
Gday, nearing completion of my TRI jet edf Boeing 727-100 which will have electronics installed very shortly, however i have just a few points to touch on, this is my first scratch built EDF aircraft i have built in 30 years of flying, (which has usually consisted of glo aircraft) and i was uncertain to a few things.
1. what volt and milliamp battery pack should i use to run: 4 HS-55 servos, and 3 GWS-50 EDF units.
2. where should my COG be? (very hard considering the swept back wing)
3.will these 3 EDF units be enough power for the aircraft ( im expecting the final product to weigh about 30oz)
thanks alot, il be sure to keep updating.
b727-77 is offline Find More Posts by b727-77
Old Jun 14, 2009, 07:47 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
It would help a lot to know what motors you're planning on putting in those fans... or is that part of the question?
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jun 14, 2009, 08:08 AM
b727-77 is offline
Joined Jul 2008
yes sorry the motors are not stock motors as i replaced them, the new motors are HXT 2040 (130L) 4850kv Brushless Inrunners.
thanks
Old Jun 14, 2009, 11:53 AM
David A Ramsey is offline
Find More Posts by David A Ramsey
New Jersey, USA
Joined May 2003
Hello again. Here's some thoughts:
BATTERY: Will depend on motor specifications. As to 4 servos; make sure your motor ESC(s) will support 4 servos.
CoG: 25 percent MAC is good. For a quick-n-dirty estimate; Using one side/half of your assembled swept wing, judge 25% of inboard swept wing panel at mid (50%) span cord. Do the same for the outboard swept wing panel. Half way between these 2 points will approximate 25% MAC of the whole wing. This will be close to a more careful assessment. Hope that was understandable.
3 EDF FANS??? I would go for only 2. A center/fuselage EDF that opporates with effeciency will be a nightmare to work out in your scale. You will be adding fan, ESC and battery weight. At best, I feel, the thrust from this fan may only support the weight it adds.
GWS press-on fans will not stay on a 1.5mm motor shaft at brushless rpms. You'll need an aluminum addapter. Currently, as far as I know, non are available. Heat is a consideration here also.
Keep your wing loading as light as possible. Thrust to weigh: (1 thrust) : (2 weight). 1:3 might work. 1:4 with a heavy wing loading isn't worth the effort ... in this size aircraft.
2 servos total; 1 servo each for ailerons and elevator should be enough. Avoid the weight of a landing gear.
Hope this helps a bit.
David A Ramsey is offline Find More Posts by David A Ramsey
Old Apr 14, 2015, 04:38 PM
M.Monsalve is offline
Find More Posts by M.Monsalve
Joined Apr 2015
Buenas Tardes, Seria posible conseguir los planos del Boeing 727 necesito llevar a cabo este diseņo para una clase de estructuras.
M.Monsalve is offline Find More Posts by M.Monsalve
Old Apr 14, 2015, 05:40 PM
turbonut is offline
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Welcome to RC groups
Google translation
Good afternoon , may Seria get Boeing 727 planes need to carry out this design for a class of structures .
Bienvenido . este es un hilo viejo y el cartel originale no ha vuelto a partir de 2010
Boeing 727/100 For Twin Gws Edf-50 David A Ramsey Electric Ducted Fan Jet Talk 89 Sep 02, 2010 12:48 PM
Build Log Boeing 727-100 EDF b727-77 Electric Ducted Fan Jet Talk 10 Aug 30, 2008 04:53 PM
Gws 50 Edf DaleM Electric Ducted Fan Jet Talk 26 Mar 28, 2003 11:43 PM
GWS 50 edf...projects? OCTANE75 Electric Ducted Fan Jet Talk 1 May 08, 2002 05:54 PM
GWS 50 EDF Duct Inlet mtflyr Electric Ducted Fan Jet Talk 3 Apr 19, 2002 10:42 AM
