Old Feb 12, 2015, 11:09 PM
United States, CA, Vacaville
Joined Jan 2014
Idea
Adrenaline Rush stevens aero model
Hello, I'm putting one of these together and stumbled onto a great set up for motor. I acquired a hammered MCPX brushless heli for parts.... Check out how nice it fits this kit. The carbon rod included in kit fits very tightly where the shaft and bearings use to be. Trim off extra plastic bits and you have a made to order 6700kv motor ready to go.
4dnospolk is offline Find More Posts by 4dnospolk
Old Feb 12, 2015, 11:12 PM
Joined Jan 2014
This is the kit I'm referring to....
Stevens aero:
Old Feb 14, 2015, 08:39 PM
United States, SC, North Augusta
Joined May 2007
I've built a few of these little racers. I like the mount that you came up with. The only bad news is that there are no props that you can usable at 3S, given the Kv of the motor. Even the GWS 3 X 2's cant handle the rpm's. You will want the amps to be in the 9-13 range. Good luck, and let me know how it turns out
seng30904 is online now Find More Posts by seng30904
Old Feb 15, 2015, 01:54 AM
Joined Jan 2014
Thanks for your input, I was planning on running a 2 cell 7.4 volt battery with a gws 3x2 prop. It won't be as fast but i'm hoping its decent! I'm trying to finish it this upcoming week, I'll post some pics.
Old Feb 18, 2015, 08:14 PM
Joined Jan 2014
Update
Tops are bright orange and bottoms are checkers. Well..... It's easy to see!
Old Feb 19, 2015, 07:21 PM
Joined Jan 2014
Ailerons and elevator attached, and wing with blocks attached.
Old Mar 01, 2015, 12:28 AM
Joined Jan 2014
Coming along
6700 kv (0 min 28 sec)
Old Mar 09, 2015, 03:00 PM
Joined Jan 2010
hello
i was wondering if you guys gave the wing dihedral ?
i would rather keep it flat, what is your say?
thanks
crow45tech is offline Find More Posts by crow45tech
Old Mar 09, 2015, 10:15 PM
Joined Jan 2014
Getting closer! Reciever was bad from package, so waiting on replacement. Got elevator servo installed but broke horn. Ailerons installed now. Also mounted elevator tube inside boom, looks better. They fly great flat, I've never flared tips or added dihedral on past builds... This is my first rush. I hear it makes slow flight a little better.
Adrenaline Rush aileron install (0 min 14 sec)
Old Mar 09, 2015, 11:13 PM
Joined Jan 2010
very nice build, ok i will keep mine flat, see what happens, thanks
Old Mar 16, 2015, 11:48 AM
Joined Jan 2014
Finished it up! Hope to get it up for a flight soon.
Stevens aero adrenaline rush (2 min 12 sec)
Old Mar 19, 2015, 12:52 PM
Joined Jan 2014
Had time to get the CG worked out today. The AUW is
102 g with the little 200 mah battery and 130g with 800 mah batt. Stevens aero says CG is about 1 inch from LE.... Somehow I ended up needing to add 12 grams to the nose to accomplish CG with 800 mah batt. Might be due to monocote stickers on tail? And this motor is less weight than comparable motors. You'll see the weight coiled around nose! Hope to maiden soon, I'll bring the gopro :-)
Old Mar 21, 2015, 11:30 AM
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Originally Posted by crow45tech View Post
hello
thanks
A little dihedral will help it to track better. It is recommended in the original plans.
Batmanwpg is offline Find More Posts by Batmanwpg
Old Mar 26, 2015, 11:51 PM
Joined Jan 2014
Well as it turns out the shaft diameter on this little motor is 1mm. So the GWS props won't work, as there 2mm holes. I tried drilling them out and pressing them over the pinion gear, but at full speed it was to off balance. So I thought maybe a 3mm collet adaptor over the pinion gear.. This is going to work best I think... But I need a smaller prop than the one I picked up. After a minute or so of bench running I smelled hot motor. I'm pretty sure a prop the size of this one would cook it.
6700kv bl (0 min 30 sec)
Sold Stevens Aero adrenaline RUSH kit Wing&aPrayer Aircraft - Electric - Airplanes (FS/W) 1 Sep 21, 2014 01:43 PM
Sold Stevens Aero adrenaline RUSH kit + extras Wing&aPrayer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 20, 2014 09:57 PM
Sold Stevens Aero Adrenaline rush Steve Elias Aircraft - Electric - Airplanes (FS/W) 1 Aug 29, 2014 04:05 PM
For Sale Stevens Aero Adrenaline Rush jnoel Aircraft - Electric - Airplanes (FS/W) 4 Mar 21, 2014 06:59 PM
