Old Dec 08, 2013, 10:33 AM
Joined Dec 2013
Harbor Freight Generators for Field Chatrging
I'm sure this has been discussed - maybe someone can give me a thread(s) link? Any info appreciated!
shredmandan is offline Find More Posts by shredmandan
Old Dec 08, 2013, 12:01 PM
United States, MN
Joined Feb 2011
Guess what's the question? Some people use them, others prefer inverter generators. I don't think there's any threads dedicated to them. Biggest thing is they are traditional generators so they are noisy. If you are going to be around a lot of people you might want to look at an inverter generator unless you want people unhappy with you.
grimbeaver is offline Find More Posts by grimbeaver
Old Dec 08, 2013, 01:15 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Use the Advanced search engine for "Harbor Freight generators". You'll have plenty of reading.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 30, 2015, 04:55 AM
Georgia
Joined Jun 2007
2014-2015 update
At the usual sale price between 99 and 89, the small (and noisy) HF generator is a good bargain if you get a good one. This is an old thread, but the question still arises!
The HF is two cycle, and does require several hours of break-in. It may have some sort of coating in the fuel tank that gets dissolved if you use the usual 10% Ethanol gas we have in the US.
(Take the carb bowl off, clean things out, etc.) I had several of these generators before I needed to get a higher power unit.
Of those I had, One failed with engine lockup during break-in after about two hours. One failed when the ignition module quit after about an hours run. I had to clean the fuel system out on another one, due to the tank anti corrosion coating mentioned above. So, spring for the exchange warranty!
After break-in, you may need to adjust the governor a small amount to reduce or eliminate engine RPM "hunting".
For the price and higher power, I replaced the HF units with first a Ryobi 2200i. and when that wasn't quite enough, a Sportsman 3500i. Both are inverter types. The first sportsman ran very well, but the case and one axle had been damaged in shipment. The replacement started and ran four about an hour, then quit. The ignition module failed! Swapped it with the one from the damaged unit before I returned the damaged one! After that, the Sportsman and the Ryobi seem to work well. You can buy both for the price of a comparable Honda!
chuck75 is offline Find More Posts by chuck75
Old Mar 30, 2015, 11:42 AM
United States, WA, Woodinville
Joined May 2014
For all the time you've spent screwing around, exchanging and repairing practically brand new units and dealing with downtime due to failed ignition modules, that doesn't sound like much of a bargain. Personally I'd gladly spend the extra on the Honda and be confident that when I need it, it will work. My free time is in short supply as it is, I don't want to waste it fixing stuff right out of the box.
James_S is online now Find More Posts by James_S
Wanted Harbor freight 2 inch mini chop saw ***WTB*** ATCH Aircraft - General - Miscellaneous (FS/W) 1 Dec 01, 2013 07:55 AM
Discussion Harbor Freight Black Friday OldRookie Batteries and Chargers 5 Nov 29, 2013 06:34 PM
For Sale 3 - 25" Drill Bits and I found them at Harbor Freight!!! $9.99 + S&H Plasmajoe Aircraft - General - Miscellaneous (FS/W) 11 Oct 15, 2013 02:38 PM
For Sale 3 - 25" Drill Bits and I found them at Harbor Freight!!! $9.99 + S&H Plasmajoe Aircraft - General - Miscellaneous (FS/W) 2 Sep 30, 2013 08:34 PM
Discussion Harbor Freight Generator G WILLIE Batteries and Chargers 6 Aug 24, 2009 08:11 AM
