Old Jul 11, 2013, 09:33 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
ive tried monokote over foam and it never sticks, whats your secret?
Just awesome! and quick too!
D_FAST is offline Find More Posts by D_FAST
Old Jul 11, 2013, 10:17 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I dust a light coat of 3M77 onto the foam. That needs to dry thoroughly, maybe an hour or so. It should be dry to touch with your finger with no tenancy for your skin to stick. The Monokote will stick to it some, but can be easily pulled up and repositioned. Then the heat activates the glue on the film and also the 3M77. It`s a pretty good bond.
If the 3M isn`t dry enough it tends to cause more gas underneath the film than normal, and it never seems to stick as well as when the 3M is allowed to dry completely. Even overnight drying is OK, probably even better, as long as the surface stays clean.
Also as noted earlier, Econokote is even better because there is more of a range between shrinking,sticking temps and the temp that will melt the foam. Low heat films are the best, but I`ve used regular Monokote here because that`s all that the LHS had in the color I waned, and I didn`t want to wait to order it.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jul 12, 2013, 08:17 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Airfoil Choice
Here`s the airfoil that I`ve chosen. It will be aprox a 10% thickness at the root and more like 13% at the tip.
Old Jul 13, 2013, 08:03 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Airfoil Templates
This won`t be a tutorial on cutting foam wing cores, but I am going to show a couple of time/expense saving things that I`ve learned over the years.
This is a new idea, but I`m going to cut each panel as an upper and lower section. It will have several advantages.
One is that I can match a good top with a good bottom and that will save some waste. It`s very frustrating to get a nice cut on the top and then screw up the bottom , then have to throw the whole panel away.
Another thing is that I plan to add as much of the structure as I can to the inside of the panels before the top and bottom are joined. That will leave a smoother outer finish which will be good since I`m just covering the wing with Monokote.
Last, since I`m working with 1" foam, it will be easy to do. If I had 2" foam, I`d probably just go with a more conventional cut, but it`s fun to try something new, and sometimes I come up with a keeper.
Here are some pics of the templates. They are just printed out, then I glue them to aluminum flashing material, like is used in roofing. I bought a 25ft roll from Home depot about 10 years ago for $10. You can cut the stuff easily with just regular scissors.
I used bamboo skewers, left over from my combat building, to strengthen them, but any kind of dowel would work fine.
Then I sand the edge of template with fine sand paper, like 400 grit. Make some holes in them for pins or screws to hold them to the foam. Then they are ready to use.
Old Jul 13, 2013, 11:36 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Well I`ve got the cores cut. Some trial and error, but not too much waste. On a wing where the tip cord is 50% of the root cord or less (this one is about 33%) it`s hard to get a smooth cut because the wire is moving so much faster at the root the wire gets too hot at the tip and causes grooves and foam loss.
So I ended up adding about 1/4" to the center of my tip template, with the upper and lower curves staying the same. That helped compensate for the foam loss from the hotter wire and gave me some added thickness so that I could sand out the grooves.
With a little more adjusting of the templates and some practice I could do much better, but these sanded out OK and will work fine for now.
I have the outline of the actual foam core marked except for the LE which will need to be trimmed for the balsa LE. I`m going to wait until I have the wing all glued together before I add the balsa LE, TE, and tips, and do the final sanding. So these are ready to install some spars and hard points for the main gear retracts.
Old Jul 13, 2013, 12:02 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Quick note......I`m estimating that the total weight of the bare airframe will come in at 3lbs or a little less. If I can do that I should be near my 10lb AUW target with about 4.5lbs of lipos included.
Old Jul 13, 2013, 12:38 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
Dang that looks great!
corsair nut is online now Find More Posts by corsair nut
Old Jul 13, 2013, 02:44 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Lee, at 4.5lbs of lipos, is that going to be a 2s2p set-up? And what monster fan have you built for it?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jul 13, 2013, 03:06 PM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice work Lee!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jul 13, 2013, 04:09 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Fuse weight is still just under 16oz. I`m shooting for an AUW weight of around 10lbs with a very large lipo pack 10 to 12s 8000 for very long flight times of 7 min or so. So far I seem to be on track.
I'm planning for about 3.5kw, but long flight times. I'm getting tired of 3min flights.
Old Jul 13, 2013, 07:03 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
OK, I`ve got the structure figured out. The main ancor for everything is a 5" X 16" piece of 1/8" ply. This part will tie into both the front and rear spar, and the retract mounting beams will also mount to it.
It`s kind of like the BVM flex plate system except that it won`t require a big hatch to work. The whole part won`t be able to be removed if/when it gets broken, but there is enough room so that a repair piece could be laid in and tied to it if it gets broken too badly.
The part weighs 4oz by itself, but I think it`s weight well spent. It should make the wing center and gear mounts plenty strong enough to withstand some of my poor landings without punching the gear through the top of the wing.
The spars will be 1/4" basswood/spruce, and will be slotted in the center to slip over the main plywood plate.
Old Jul 13, 2013, 07:54 PM
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
Lee:
Great job. plane looks very nice.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Jul 13, 2013, 08:40 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Here is the plate and spar assy mounted into the upper half of the cores. Just need to cut the recesses in the lower cores, check the fit, and it will be ready to glue together.
The glue will be a combo of Gorilla Glue and 3M-77. Then 5 min epoxy to glue on the LE, TE, and tip balsa.
Old Jul 14, 2013, 01:42 AM
Hampton, VA
Joined Mar 2009
Really appreciate the time spent showing how you do your wing cores.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Jul 14, 2013, 02:18 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Ksqm
No problem, it only takes a few minutes and it`s a good record for me too. I`ve gone back and checked my own threads many times because I forgot one thing or another.
This method did work out pretty well,especially for a wing that`s just going to get film directly over foam, because I was able to preserve almost all of the surface without any need for any filler.
Wanted Sniper XL Fuselage Useable......repairable damage OK Knife Liddle Aircraft - Electric - Jets (FS/W) 3 Mar 26, 2013 11:14 PM
For Sale Super Sniper 90 RTF LPU txshan130 Aircraft - Electric - Jets (FS/W) 4 Mar 22, 2013 09:01 PM
Sold Het Super Sniper XL Brickyard Aircraft - Electric - Jets (FS/W) 11 Mar 17, 2013 11:32 PM
Sold Super Sniper 90 XL V2 Hossinarizona Aircraft - Electric - Jets (FS/W) 4 Feb 08, 2013 03:35 PM
Sold Super Sniper XL V2 Hossinarizona Aircraft - Electric - Jets (FS/W) 4 Feb 08, 2013 03:34 PM
