Old Jan 15, 2012, 02:58 PM
Ireland
Joined Jun 2011
nine eagles sky eagle motor
hi, my new nine eagles sky eagle motor will not hold throtlle when i push throttle it spins for about 1 second then stops battery is fully charged help would be much appreciated jamie
jamiek123 is offline Find More Posts by jamiek123
Old Jan 16, 2012, 05:04 AM
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
clean the battery contacts and try again.
If that fails then there's likely a bad connection either between the motor and RX or between the batt connector and the RX. Check those.
Hope this helps.
SS
starscream4002 is offline Find More Posts by starscream4002
Old Jan 16, 2012, 03:31 PM
New Zealand, Canterbury, Rolleston
Joined Oct 2011
If it is a new motor this shouldn't be the fault but after using one of these motors for a few flights, the "thrust washer", (a plastic tube over the motor shaft), melts and the windings rub against the front of the motor housing and wear through and short. There should be less than 1 mm of end float (in and out movement) of the motor shaft. Once it is more than that the motor will fail.
I suspect these motors are built for helicopters and in that case don't have the pull of the propeller to contend with. Other small planes (Champ etc.) use gears and again the motor doesn't need a thrust washer.
I have tried "pre-building' by replacing the plastic tube and putting a 2 mm length of hypodermic tubing over the shaft and a 1 mm copper wire washer in front of that but because of the tight fit it is easy to short through the winding insulation and it doesn't work. The copper washer is made by taking 1 mm wire and wrapping it round the motor shaft and cutting off. Also flattening it a bit with pliers. Even doing this in front of the plastic tube helps the motor life.
The real answer would seem to be changing the electronics and fitting a brushless motor. I'm in the precess of doing this.
See - http://www.rcgroups.com/forums/showthread.php?t=1502317
Mac50L is offline Find More Posts by Mac50L
Discussion Cox Sky Ranger, Extra 300 / Nine Eagles Sky Eagle Brushless & Spektrum ShokWaveRider Scratchbuilt Indoor and Micro Models 19 Jun 19, 2012 07:25 AM
Sold Cox Sky Ranger or Nine Eagles Sky Eagle Airframes ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Nov 19, 2011 02:21 PM
Sold Cox Sky Ranger / Nine Eagles Sky Eagle Micro RX Brick and Motor ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 11, 2011 09:22 AM
Discussion slow fly motor for nine eagles sky eagle jamiek123 Power Systems 1 Aug 21, 2011 10:58 AM
Discussion Nine Eagles Sky Eagle chris_wade Beginner Training Area (Aircraft-Electric) 3 Apr 28, 2011 03:50 PM
