Old Jan 20, 2010, 12:43 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Build Log
BAC 1-11 One eleven & Super One Eleven!
This thread will detail the construction of this classic British airliner.
I humbley appologize to everyone but I SUCK at making PDF plans, I really do
so I'll try and give the best info I can, If anyone can help me make PDF plan files I'd be greatfull.
Specs:OA lenght 69.75 inches
Wingspan 69 inches
weight 2 pounds max
2 55-65mm edf's
2 14V 3000mah poly-lipos
2 HXT 2835 (380S) 3900kv Brushless Inrunners
4 micro metal gear servos
demondriver is offline Find More Posts by demondriver
Old Jan 20, 2010, 02:39 PM
Up-Out-&-Gone
Joined Mar 2007
Whenever I build a plane from scratch I buy a plastic or die-cast model of the plane, it can really help look at the overall shape of the plane.
Old Jan 20, 2010, 09:34 PM
Up-Out-&-Gone
Joined Mar 2007
I find taping 20-50 peices of printer paper together to make your plans is just to irratating to me that is, so I just make my plans by hand.
Old Jan 21, 2010, 02:59 AM
Up-Out-&-Gone
Joined Mar 2007
Here's the begining of the One-eleven's fuselage it's on 32" X1" X7.5"
piece of pink foam & 2 round body ends with a carbon fiber rod as the main backbone, like my DC-9 these airliners are basically park flyers my Local flight field is all grass so I have to rely on hand launching and belly landings so I've gotta build these birds ford tough.
Old Jan 21, 2010, 10:04 AM
Up-Out-&-Gone
Joined Mar 2007
The Tail of the One-eleven is simply cut from a peice of blue Dow-styrofoam
you'll find it at lowes.
Old Jan 21, 2010, 10:53 AM
You know how we do
Spitfire222's Avatar
Maryland
Joined Jan 2010
Looking good! Interesting subject. Nice MSFS screenshot at the top!
Spitfire222 is offline Find More Posts by Spitfire222
Old Jan 21, 2010, 02:15 PM
Up-Out-&-Gone
Joined Mar 2007
Thanks! here are the main fusalge ribs before I wrap it in 2mm depron.
Old Jan 21, 2010, 07:47 PM
Up-Out-&-Gone
Joined Mar 2007
In this photo I've epoxied the 2mm depron to the 1-11's fuselage ribs with pins, next I'll expoxy the deprom around the top half of the fuselage.
Old Jan 21, 2010, 08:00 PM
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Subscribed
RogueTitan is offline Find More Posts by RogueTitan
Old Jan 21, 2010, 08:05 PM
Up-Out-&-Gone
Joined Mar 2007
You see how I bend the depron around the fuselage, it's very straight forward.
Great to have you on board RogueTitan!
Old Jan 21, 2010, 08:47 PM
Up-Out-&-Gone
Joined Mar 2007
Once this part of the plane is done the rest is smooth sailing you make you wing box & wings make your tail, then build you nose & rear fuselage.
Old Jan 21, 2010, 10:47 PM
Joined Nov 2005
subscribed, this is going to be awesome.
Soulreaper
soulreaper is offline Find More Posts by soulreaper
Old Jan 21, 2010, 11:16 PM
Up-Out-&-Gone
Joined Mar 2007
Thanks SoulReaper!
Here's the completed fuselage tube, next the wings! Unlike my DC-9
the One-Eleven has a wide wing span, so she's gonna be a great soaring
park-liner.
Old Jan 21, 2010, 11:46 PM
Up-Out-&-Gone
Joined Mar 2007
http://www.youtube.com/watch?v=ynheFnh8geI
Here's one for the 60's airliner nostalgia nut! Like me!
Old Jan 22, 2010, 12:50 PM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Looking good!
What is your idea for propulsion?
Ben_E
Ben_E is offline Find More Posts by Ben_E
Sparky's OV-1 Mohawk! dawnron1 Scale Kit/Scratch Built 357 Today 12:17 PM
Discussion DX7 batt voltage problem model 1-10 fine 11-20 it drops to 9.0? any one epoweredrc Radios 13 Dec 30, 2009 01:50 PM
Discussion OV-1 Mohawk lmopar69 Electric Warbirds 6 Apr 19, 2006 08:41 AM
Rittinger OV-1 Mohawk Construction Rudderman98 Scale Kit/Scratch Built 193 Jan 23, 2006 10:02 PM
FS: NIB Titanic Airlines sp280 2/1 or 3/1 GD rcgreaves Aircraft - Electric - Airplanes (FS/W) 0 Dec 29, 2002 09:17 PM
