Old Mar 05, 2013, 10:53 AM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
losi ten rear hubs necessary?
I want to hop up my truck but dont really want to spend extra cash if i dont have to. Are these rear hubs really worth changing to the aluminum ones? Also why do they onky make aluminum rear hubs and not the front?
flysohigh is offline Find More Posts by flysohigh
Old Mar 05, 2013, 08:22 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you're not breaking the plastic hubs you'll see no difference by running the aluminum ones.
wparsons is offline Find More Posts by wparsons
Old Mar 05, 2013, 09:02 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
I guess they are really durable I have not seen people had any problems with them I guess I will just worry about the things that I really need actually I was thinking about getting the aluminum shock caps but I actually see the plastic ones without any problems I'm just going to wait till things break and then I upgrade as I go. any other things that I can do from how the truck comes stock that you recommend to upgrade or change?
Old Mar 05, 2013, 09:23 PM
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
That sounds like a good idea no sense spending money if you don't have to. I might check at the local track and see what other people are getting for that truck. Practice is the cheapest upgrade you can ever buy
mredzadventure is online now Find More Posts by mredzadventure
Old Mar 05, 2013, 09:46 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
I agree i was looking at the TLR tuning kit dont understand the adjustable hinge pins what they do?
Old Mar 06, 2013, 04:52 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I don't think they're adjustable hinge pins...
Rear Shock Tower, Carbon, 4mm
Front Shock Tower, Carbon, 4mm
Rear Hubs, Aluminum
Shock Tops, Aluminum
One Piece Shock Standoffs
Shock Collars, Aluminum
Adjustable Front Hinge Pin Holder Set
Adjustable Rear Hinge Pin Holder Set
It sounds like it's the piece that contains them to the chassis that is adjustable.
Old Mar 06, 2013, 05:02 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
So then the chassis has 2 different points to insert the pins. Inner and outer but what are all those black inserts for?
Old Mar 07, 2013, 03:45 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Probably offset to adjust toe angle on the rear?
For Sale Losi Ten SCTE weezypain Cars - Trucks and Parts (FS/W) 13 Jul 10, 2013 05:10 PM
Sold LOSI SCTE TEN Brushless 550 2800Kv 4 Pole Sensorless Motor by Losi LOSB9444 tonebone Cars - Trucks and Parts (FS/W) 0 Mar 04, 2013 10:28 AM
For Sale 2 Losi (TLR) TEN SCT Trucks RTR New In Box $499 each Shipped rz22g Cars - Cars and Parts (FS/W) 0 Jan 12, 2013 06:16 PM
For Sale Pro-Line Pro Trac rear hub carriers 6062-05 2wd downtown0309 Cars - Trucks and Parts (FS/W) 0 Jan 02, 2013 11:36 PM
For Sale Pro-Line Pro Trac rear hub carriers 6062-05 2wd downtown0309 Cars - Accessories (FS/W) 0 Jan 02, 2013 09:36 PM
