Old May 08, 2013, 12:21 AM
Australia, VIC, Melbourne
Joined Nov 2006
It looks very good.
I got one of those X-Flight combos..... the motor bearings were rubbish/noisy, just as it came!
So I never used it. And costs more for decent bearings than that motor is worth.
120 Mph.... fast enough for me!!
PeterVRC is online now Find More Posts by PeterVRC
Latest blog entry: Skyzone Goggles - Button Shield
Old May 08, 2013, 06:25 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by PeterVRC View Post
It looks very good.
Those "rubbish" bearings are holding up fine in a number of my setups. I think the secret is to make sure they are glued into the motor (or they will rotate and rattle) and have the motor & fan balanced separately then dynamically balanced.
4stripes is online now Find More Posts by 4stripes
Latest blog entry: Some photos of the EDF fleet!
Old May 08, 2013, 09:03 AM
Joined Nov 2006
I can feel the bearing 'graunch' when turned slowly by hand and putting lateral pressure on them. If it was all well balanced then it would reduce that somewhat. And other than that... it could just be used and flogged to its death! LOL
But no plane I do ever gets 'sacrificed' for that, as I don't want any in-flight failures. The plane is worth more than the $20 motor!
Old May 08, 2013, 05:25 PM
4stripes's Avatar
Joined Jan 2009
I agree Peter, If your bearings are shot, it's time to change them. The motors I have don't have that problem. They did have loose bearing mounts but that was fixed. The power they produce is perfect for my models in the 3kg range (give or take half a kilo).
Cheers
Old May 08, 2013, 10:05 PM
rush1's Avatar
United States, CA, Palmdale
Joined Mar 2011
I have another xflight set up in my T45 that's whisper quiet , But I think you guys are probably correct because the one that's in my F100 has always been noisy . yeah 120 is fast enough for me too ! But these things are great flying planes , This one is grounded because I'm getting flutter now that I never had before and after looking at the wings I'm getting stress cracks all along the bottom side and the foam skins have debonded so I'm going to cover the bottom of the wings in 1/2 oz fiberglass , Now I'm regretting not putting a spar in it , I guess I'll have to build another one .
rush1 is online now Find More Posts by rush1
Old Aug 01, 2014, 08:33 PM
4stripes's Avatar
Joined Jan 2009
Mirage has new double nose wheel leg now (since it worked so well in our Phantom).
The weight on the front leg is pretty light with the mains moved close to the CG so it will handle the odd grass landing. The leg was purchased as a set of 3 from HK. All three are the same legs but one has smaller wheels. The legs needed to be lengthened with a section from an old Flyfly oleo leg.
http://www.hobbyking.com/hobbyking/s...dproduct=45229
A separate Turnigy 5-7amp BEC (running from the main battery) was added last year as insurance incase of a ESC failure.
Old Aug 02, 2014, 12:21 AM
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Looks Stunning great job
Sluf7 is offline Find More Posts by Sluf7
Wanted Changesun 90mm Ducted Fan (12 blade)with 1600kv motor Low Show Aircraft - Electric - Jets (FS/W) 1 Nov 26, 2012 02:44 PM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 06:52 PM
For Sale LPU ViperJet Fiberglass 90mm EDF and Changesun 12 blades $300 AERO46 Aircraft - Electric - Jets (FS/W) 4 May 10, 2012 03:11 PM
For Sale 90mm Fly Fly mirage 2000 new in box zaskarkid Aircraft - Electric - Jets (FS/W) 0 Dec 28, 2009 08:19 AM
Sold Fly Fly Mirage 2000 (90mm) Buzz Bomb Aircraft - Electric - Jets (FS/W) 4 Apr 05, 2009 07:38 PM
