Old Aug 19, 2013, 06:37 PM
Need a bigger runway
sandydr's Avatar
Dominican Republic, Puerto Plata, Cabarete
Joined Mar 2008
Thanks epoxyearl,
I remember the doublers being used for added strength near the struts for the GP Bi-plane I built and assume that these are for where the aileron servos should be. What am getting confused about...is that there are 2 distinct looking pieces which are both labelled as W1A and the photos from the manual are not helping. This one is definitely being built on 'Caribbean' time..... 6 months in and I am only on pg 9 !
sandydr is offline Find More Posts by sandydr
Old Aug 19, 2013, 06:41 PM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Look for the part(s) on the plan, not the manual. It may give you a different perspective on the problem.
TomCrump is offline Find More Posts by TomCrump
Old Aug 19, 2013, 07:07 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Obeying Tom's commands, I looked at what part of the plans you showed...Those doublers appear to be the receivers for the wing tube..You should not have to cut or shape any doubler parts, if they are die-cut-only light sanding is required..
If you'll take the wing tube and stand it vertically in the rib, while the rib is flat on the surface, those doublers fit around it to lock it in place..
Momentarily forget the markings, and assemble parts that look like the pictures....that's the bottom line... Don't glue anything until you're positive you have the right parts in the correct place.
You'll figure it out soon.
epoxyearl is online now Find More Posts by epoxyearl
Old Aug 19, 2013, 10:18 PM
sandydr's Avatar
Joined Mar 2008
Tom/Earl,
Appreciate the tips. I can see how the ribs fit around the wing tube, I just can't seem to see any U shaped doublers in the box. Will give it a look with a fresh pair of eyes in the morning. All the best, Sandy
Old Aug 20, 2013, 06:58 AM
epoxyearl's Avatar
Joined Oct 2011
missing parts.
I can cut the missing parts for you. I'll need you to send a copy of the outline of the parts from the plans. I have lots of balsa and plywood.
Let me know if you can't find them in the kit.
Old Aug 20, 2013, 12:57 PM
sandydr's Avatar
Joined Mar 2008
That's really kind of you and the offer is really appreciated. I have some balsa here and ply, so worst case I should be able to cut it myself. Getting sidetracked today with installing some flaps on a foamy....anything to avoid going through the box again! All the best, Sandy
Old Dec 31, 2013, 06:51 PM
Keep calm and carry on.
Oso M's Avatar
United States, VA, Falls Church
Joined Jan 2012
Originally Posted by sandydr View Post
Tom/Earl,
Sandy, i just got done with one wing.
Those two parts do go on the wing, they are the ribs that go on the leading edge of the wing at the root, where the wing mounting dowel will inserted. Does that make sense?
Oso M is offline Find More Posts by Oso M
Old Jan 01, 2014, 09:23 PM
sandydr's Avatar
Joined Mar 2008
Thanks Oso,
Managed to move on from there a while back. I have finished the construction and started covering, but had to down tools for a vacation Hopefully should have everything done in the next 2 weeks.
Regards, Sandy
Discussion Super Decathlon, Dynaflite 89" Span Lnagel Scale Kit/Scratch Built 8 Apr 17, 2014 11:35 PM
Gallery Dynaflite Super Decathlon build thread tomerj Giant Scale Airplanes 142 Jan 03, 2014 01:33 PM
Sold Dynaflite Super Decathlon PEDANTIC Aircraft - Fuel - Airplanes (FS/W) 2 Sep 09, 2011 09:03 PM
FS : On E-bay Dynaflite Giant Super Decathlon Kit 1.08-1.8 NIB Chris K Aircraft - Fuel - Airplanes (FS/W) 0 May 23, 2005 09:01 PM
Dynaflite Super Decathlon power plant mRqS Giant Scale Airplanes 6 Sep 16, 2004 01:56 PM
