Old Aug 12, 2011, 11:35 AM
J40
Airplanus Erectus
Fairfield,Pa.
Joined Feb 2002
Question
Help with motor?
I have an old Wattage Cap 232EP that had the Cobalt 400DD. Was always a sled. Set on it along time now. I have sitting around:
1. Eonxlite 11.1vdc 3S 25C 1300mah. lipo.
2. Supertiger 30A BL esc for lipo.
3. Want to use APC 7 X 4 props due to ground clearance (and looks good)
4. approx 28oz. all up weight.
Any Tower Hobbies in runners work for this?
Any recommended in runners?
Thanks for any help!
J40 is offline Find More Posts by J40
Old Aug 12, 2011, 12:01 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Finding an inrunner with low enough Kv to spin a 7x4 on 3s will be hard. If you intend to use it geared then life gets easier.
Something like this might do the trick (once they are back in stock!): http://www.hobbyking.com/hobbyking/s..._Inrunner.html [one review says about 30A/350W with a 7x4]
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Aug 12, 2011, 01:16 PM
J40
Airplanus Erectus
Fairfield,Pa.
Joined Feb 2002
Thanks Doc. Firewall is set up for the original can motor and mount method is light. Will be plug and play if I can find the right one. Out of stock.
Old Aug 15, 2011, 09:58 AM
J40
Airplanus Erectus
Fairfield,Pa.
Joined Feb 2002
Anyone else have a suggestion?
Old Aug 15, 2011, 05:13 PM
Dr Kiwi's Avatar
Joined May 2003
ARC 28-47-3 (~1460Kv)... draws 20.30A/235W with a 7x5 APC E on 3s. (31oz @ 64mph). With a 7x4 APC Sport it draws 15.70A and gets you ~28oz @ 55mph.
www.lightflightrc.com
Old Aug 16, 2011, 11:41 AM
J40
Airplanus Erectus
Fairfield,Pa.
Joined Feb 2002
Hey Doc, that looks nice. Thanks.
Discussion Help Needed on chosing a glider with motor in the fuselage woreoutpilot Sailplane Talk 3 Jul 21, 2011 08:28 PM
Help! Help with an UK sourced alternative for the KDA 20-50S Brushless motor. Sebbie Power Systems 3 Jul 17, 2011 09:06 AM
Discussion Help Needed on chosing a glider with motor in the fuselage woreoutpilot Electric Sailplanes 2 Jul 16, 2011 04:16 PM
Discussion Help Needed on chosing a glider with motor in the fuselage woreoutpilot Scale Sailplanes 2 Jul 15, 2011 11:13 PM
Discussion troubleshooting help with esc/motor chevronflyer Electric Plane Talk 23 Jul 10, 2011 07:36 AM
