Old Oct 19, 2012, 08:52 PM
Joined Dec 2008
After all this reading about how telemetry decreases flight time I decided to test this. I inhibited the voltage/temp sensors and rebooted my radio. I didn't notice any increase in flying time at all. I have one of the first mini's and I never upgraded the receiver. Not sure how some are seeing any difference, maybe there's a couple versions of this receiver made.
PeteAir is offline Find More Posts by PeteAir
Old Oct 19, 2012, 11:27 PM
United States, ND, Bismarck
Joined Mar 2012
I have noticed the same thing on my ladybird, it was one of the first ones released. I have noticed no difference in flight time with telemetry inhibited and enabled. It has only voltage, no temperature. I get 8.30-9:00 either way before it hits its cut off. (with some ebay 350mah batteries)
flint723 is offline Find More Posts by flint723
Old Oct 21, 2012, 01:26 AM
Joined Oct 2012
Do some body know how to keep the stock battery powerful?
andy6622 is offline Find More Posts by andy6622
Old Oct 21, 2012, 06:50 PM
Joined Dec 2008
Does anyone know if the receiver firmware upgrade fixes the tail drift issue? Seems to me like when the heli warms up or longer you use it, then it drifts worse. Deciding whether or not its worth it to upgrade the receiver.
Old Oct 21, 2012, 06:59 PM
Joined Oct 2010
You have to let those little brushless motors cool off. They get extremely hot if you fly more than once back to back. You also shorten the motors life that way.
pmerritt is offline Find More Posts by pmerritt
Old Oct 21, 2012, 09:03 PM
Austria
Joined Sep 2008
My Mini CP is on the way!
What mods do i have to do before the first flight? If i try the servo saver mod will the horns slip during flight and full pitch pumps?
helicopter_new is offline Find More Posts by helicopter_new
Old Oct 21, 2012, 10:19 PM
i812's Avatar
Joined Aug 2009
I haven't upgraded the RX firmware, but noticed if I land, unplug and immediately replug the RX's LiPo then the Tail drift will reset to zero again, and once again slowly accumulate with time the longer I fly. Most of the times, I'm using the RUD stick to navigate, so I really don't notice the Tail drift unless I'm hovering
i812 is offline Find More Posts by i812
Old Oct 21, 2012, 10:35 PM
i812's Avatar
Joined Aug 2009
Originally Posted by i812 View Post
Below are some mods many people believe should be done to the Mini CP as soon as possible:
  • Servo Saver mod - Bytemuncher's RCG Blog has detailed info.
  • RX Saver Mod - Attach a somewhat stiff support from bottom of Battery Tray so it extends inside the bottom of the Canopy and helps keep the Canopy from easily sliding upwards when it is hit from the bottom. Marioinc posted details. I think if this mod (or any other mod that keeps the bottom of the Canopy from easily pivoting upward) is performed, then there might not be a need to do the RX Coil Saver mod.
  • Canopy Saver Mod - Apply a strip of tape along the entire bottom edge of the Canopy. The Canopy is very durable; however, it easily splits starting from the bottom edge, and then over time the split travels towards the nose. Hopefully taping the entire bottom edge of the Canopy will prevent splits from starting.
  • RX Coil Saver mod - Apply adhesive (Hot Glue, X2 White Gorilla Glue, CA, etc.) to Coil at front lower right corner of RX board, so Coil doesn't break when Canopy is taken off (in a crash?). If the Coil lead(s) has broken from the PWB and the lead(s) is too short to re-solder to the PWB, it can be carefully unwound as required (one of the Coil's leads easily unwinds one loop at a time from the outside inwards; however the other lead has its end exposed but immediately get buried under all the windings - it that lead is too short, probably the other lead will need to be completely unwound, so the coil can be rewound with long enough leads at each end), rewind as necessary (depending on which Coil wire lead broke from PWB), and re-solder as required. I think the Coil can be replaced for about $0.35 + $2.80 shipping from DigiKey.com; however, we should get one and verify it works before publicizing the Part Number.
  • RX Antenna end - Keep it as vertical as possible - this will keep its exposed bare tip from electrically shorting against the Motor or RX circuitry, and have the Antenna positioned for best signal reception. Some people feel safer insulating (Liquid Electrical Tape, X2 White Gorilla Glue, Hot Glue, Heatshrink, etc.) the exposed wire at the tip of Antenna.
After the Servo Holder's - Canopy Holder Rod breaks from a strong crash, Hot Glue a 38 mm (1.5 inch) length of 1 mm CF Rod centered across the back of the Servo Holder above the Servo Holder Guide Pin and Screw Head. If at a later time the Servo Holder needs to be removed, the Hot Glue and Canopy Holder Rod can be removed as required.
At first, I had problems with the Servo Saver mod slipping during full stick Max to Min pitch pumps, then upon close examination noticed the problem was due to me programming the TX to use 100% Pitch Travel, which was causing the top 2 Links to mechanically bind with the Blade Grips, preventing full travel to 100%. The Servo Saver Mod was slipping during the binding, and therefore were functioning by not allowing the Servo Gear to strip. Once I decreased the TX's Pitch travel back down to the factory recommended 6x% (I forgot the exact % specified in the User Manual), the Servo Saver Mod stopped slipping unless I crashed.
Old Oct 22, 2012, 05:19 AM
Austria
Joined Sep 2008
Thanks i812.
I've read that many people face drift problems. What transmitter are they use? Is it a specific transmitter's bug or receiver's bug in general?
Old Oct 22, 2012, 06:27 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
Thanks i812.
What drift? Tail drift is caused by the tail motor. I have 6 tail motors, 4 are perfect, 1 has a CW drift, and another one has a CCW drift.
sbstnp is offline Find More Posts by sbstnp
Old Oct 22, 2012, 07:46 AM
Joined Sep 2012
Originally Posted by sbstnp View Post
Triple check connectors. Are you sure it is power and not pitch servo or aything else?
Thank you all that suggested ideas! I found out that the connector from motor to ESC was bad, now it works great!!! What a difference between C05 and stock motor!! It may be expensive, but it's worth the price...
dariobrit is offline Find More Posts by dariobrit
Old Oct 22, 2012, 09:53 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
Happy to hear you solved the problem. Once you don't tinker with it anymore, soldering everything in place is the way to go.
Old Oct 23, 2012, 10:56 AM
Joined Jul 2008
I am ordering a flashed xp7a to use with one of my rewound c05's. I hope to get a governed mini by next week! I had to mention to Dylan at www.astroid-designs.myshopify.com that the xp7a needed to not only have the xp7a programmed for main but also to have the input polarity set as negative. I spoke to sskaug over at helifreak who is the main guy with blheli. He said that mcpx owners could change the polarity using the transmitter to program the esc. But he didnt know for certain if the same could be done with a Walkera. So for those of you wanting to go the blheli route. Make sure to have the polarity set to negative. It doesnt much matter though if you have the blheli usb programming stick though. I cant afford the blheli stick right now though so Dylan at www.astroid-designs.myshopify.com offers flashing for 5 bucks! not bad.
I think my next cash adventure with the minicp will be a hp05, then a xp3a for the hp03t tail motor. Then , who knows! it never seems to end.
mescalinedream is offline Find More Posts by mescalinedream
Old Oct 23, 2012, 11:51 AM
United Kingdom, Bristol
Joined Aug 2008
Hi
Could i offer a suggestion? On helifreaks Olli Thread you could use Only Arduino Nano V3.0 or Arduino Uno plus one servo lead.
Don't need LCD at all maybe later and you'd have all you need to use blheli to its fullest and other projects pretty much all you'll ever need for ESC AVR/Silicon Labs
There is a lot that can be changed and your setup can be saved and shared with others.
DX.com have one for 12$ http://dx.com/p/nano-v3-0-avr-atmega...-118037?item=2
Ps if you have Multiwii control board you could use that
SadSack is offline Find More Posts by SadSack
Old Oct 23, 2012, 01:38 PM
Deviant
sbstnp's Avatar
Joined Jul 2012
Read this thread: http://www.helifreak.com/showthread.php?t=443048
I never had success tapping signal from the motor plug, I had to tap a FET on the back of the RX board. The signal I got there is POSITIVE, so you might need to change the polarity. Works great.
Another option for you would have been to get a 10A V3, kind of expensive at the usual places and HK where it was cheapest is out of stock (I bought one, still in customs, great price around $14).
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9859 Dec 04, 2014 12:01 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 15 Dec 03, 2014 12:27 PM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 12:38 PM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 08:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
