Old Dec 19, 2011, 06:30 PM
Pattern_is_fun's Avatar
United States, CO, Westminster
Joined Sep 2004
Who's using the X2 charger ? Thoughts?
I'm looking for a new 6S charger - charging 2 at a time. Anyone using the Hitec X2 Ultima Dual charger?
Any comments appreciated.
Scott
Pattern_is_fun is offline Find More Posts by Pattern_is_fun
Old Dec 20, 2011, 01:22 PM
Dallas, TX
Joined Jan 2005
Current reading is not the most accurate but it works. I do like the iChargers better because they are more accurate and the charge cutoff points are adjustable. Not that it makes a big difference but for example to charge LiFe the X2 charge cutoff is 3.6 per cell while with the iChargers I like to set it to 3.65. Again not a big deal.
Alan
jh2rc97 is offline Find More Posts by jh2rc97
Old Jan 30, 2012, 04:31 PM
Joined Feb 2010
I've had one a couple months now and like it. When charging 6s on port #2 I find one of the cells always reads high(0.05v) no matter which pack. But as it turns out it is not a safety issue because reading high just means it will starting throttling the current sooner toward the end of charge than it would otherwise. So its okay and happens on just one the port. So if I am doing 2x6s port #2 finishes a little later than port #1.
db_sonic is offline Find More Posts by db_sonic
Question Who here has ever had a Major LiPoy incident while using a balancing charger? everydayflyer Batteries and Chargers 58 Feb 16, 2014 10:05 AM
Discussion Who's using or has a Stumax 100mm Fan? avaiojet Electric Ducted Fan Jet Talk 10 Aug 09, 2011 01:25 PM
Discussion Thoughts on using a handheld anemometer RTF Thumper Electric Plane Talk 15 Jun 25, 2011 06:44 PM
Discussion ESC's---Who's using what? JT Electric Ducted Fan Jet Talk 12 Aug 29, 2010 07:18 AM
Question Blade 400 Owners - Who's Using Stock Charger? mitchfx Mini Helis 8 Apr 27, 2008 11:45 PM
