Old Sep 24, 2014, 07:42 AM
Oman
Joined Aug 2014
Question
sizes of propellers
hello
any one have details about types and sizes of different propellers and what proper job each one can does
is ther any formula lets me making correct selection if i want ??
ali74 is offline Find More Posts by ali74
Old Sep 24, 2014, 09:10 AM
United States, IL, Glenwood
Joined Nov 2013
Way to many variables. Narrow it down. What are you looking for a prop for? What plane, and what motor and esc? Also what type of flying do you plan on doing.
Gregertman is online now Find More Posts by Gregertman
Old Sep 24, 2014, 03:57 PM
Oman
Joined Aug 2014
do i understand from you that there is no standard formula used to sellect correct propeller without mention the motor, esc and type of flying ??
Old Sep 24, 2014, 04:13 PM
Gold Coast Coolangata, Australia
Joined Nov 2003
Google search is your friend!
Try searching for ' formulas for model aircraft' and you will see many, such as;
http://www.airfieldmodels.com/inform...raft/formulas/
Also, there are very good online sites that include performance calculators that help you see the diff's between diff prop sizes/pitch. Like Ecalc;
http://www.ecalc.ch/motorcalc.php?castle&lang=en
Also, for electrics you need to understand the basics such as motor kv and ohm's law. Again, lots of good info can be obtained by Google. Have fun!
TomC is offline Find More Posts by TomC
Old Sep 24, 2014, 04:41 PM
Oman
Joined Aug 2014
thank you tomC
great idea
Old Sep 25, 2014, 08:14 AM
I like the violent stuff!
Costa Mesa, CA
For basic starters. Prop diameter should be 25-28 % of the wingspan of the plane. For small foamies use a slowfly prop. Pitch should not exceed 1/2 the diameter. Example, 10x4.7 should be max. Too much pitch can also draw too much current. So pitch is also related to motor kv value. A lower kv can swing a bigger prop. Good idea to start with recommended setups when starting out. Good luck and HAVE FUN!!!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Sep 25, 2014, 04:21 PM
Oman
Joined Aug 2014
everything you wrote down clear to me except (prop diameter should be 25-28%of the wingspan of the plane)
please can you give an example ???
Old Sep 25, 2014, 06:30 PM
Joined Jun 2013
40 inch wingspan, 10 inch prop. = 25%
LongGone is offline Find More Posts by LongGone
Old Sep 25, 2014, 09:42 PM
Oman
Joined Aug 2014
thank you indeed
Discussion Battery size and Propeller Size Help!! jstang50 Batteries and Chargers 11 Sep 26, 2014 02:46 PM
Help! Propeller size issue! EraJomppa Multirotor Talk 13 Nov 14, 2013 03:56 AM
Question Going to larger size propellers, how much pitch reduction to compensate? RC Aerobat Electric Plane Talk 9 Oct 04, 2013 08:33 AM
Propeller Clerance and Propeller Size okan Power Systems 1 Dec 30, 2002 12:08 PM
