Old Nov 20, 2013, 02:35 PM
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
Question
Can the PL8 charge through balance taps only? Is that known as Node-Only?
Title pretty much presents the question. Can I charge so 4S Prismatic LiFePo4 packs using an MPA and connecting only the balance taps? I realize it would be a less than one Amp charge but versus what I have to do to get the batteries out of their tube, time required is not an issue.
BVH is online now Find More Posts by BVH
Old Nov 20, 2013, 05:27 PM
Seattle
Joined Sep 2007
The PL8 supports node only charging in FMA wire mode. These feature is one of the things that is lost when you move to JST-XH wiring mode. There are advantages to JST-XH wiring mode. Namely parallel boards. The MPA requires JST-XH wiring mode.
I'd get an FMA pigtail and whip up your own adapter with the main leads in parallel. Increase the charge rate, simplifies charging and does not require toggling the wiring modes to use.
Gregor99 is online now Find More Posts by Gregor99
Old Nov 20, 2013, 10:49 PM
USA
Joined Jan 2002
I do it all the time. I still have some nitro machines and charge my RX packs (2s LiFe) using only the balance leads. It works great and it's one less cord I need to connect which is easier as these packs remain in the aircraft while charging.
Ohmic is online now Find More Posts by Ohmic
Old Nov 21, 2013, 01:16 AM
Seattle
Joined Sep 2007
Are you changing wiring modes? Or are of your adapters using FMA wiring mode? I held out as long as I could with FMA wiring mode. Eventually switched over to JST-XH mainly for testing purposes as well as the MPA. Converted all my balance cables over to JST-XH.
Old Nov 21, 2013, 01:24 AM
USA
Joined Jan 2002
I'm a diehard, never used XH mode, not even once in the three years I had my two PL8s. I got my PL8's long before the MPA boards came out and when I got them I all all the FMA adapters so I could use any batteries.
However, I also realize the end is near and it's only a matter of time before I raise the white flag and use XH mode.
Old Nov 21, 2013, 04:50 PM
Seattle
Joined Sep 2007
I hear you. I was the same way. Even made my own parallel cables that were wired using the FMA wiring mode. Here's a little known tidbit. My favorite thing about FMA wiring mode (PL8 only) is that all LiPo presets can be used to charge 1s without a balance lead. On the PL6 you have to use the unbalanced preset. There is no storage preset for 1s either. I did create a storage preset for the PL6 and uploaded it here. http://www.rcgroups.com/forums/showthread.php?t=1837319
For the DPL there are two new 1s presets. One for high power charging and one for storage.
Old Nov 22, 2013, 11:15 AM
BVH
BVH's Avatar
Joined Dec 2006
Thanks for all the info everyone.
Old Nov 22, 2013, 11:38 AM
USA
Joined Jan 2002
Here's a little known tidbit. My favorite thing about FMA wiring mode (PL8 only) is that all LiPo presets can be used without a balance lead.[/url]
Wow, I never knew that. I stopped using LiIon as 2s RX packs a while back due to their limited charge rates. I think all my packs have balance leads these days except for some old small 280mAh 2s packs for for indoor flying. I can't believe these 10 year old packs still work, but they seemed decent when I flew them last year.
Old Nov 22, 2013, 11:44 AM
Seattle
Joined Sep 2007
Correction
Iall LiPo presets can be used to charge 1s without a balance lead.
Old Nov 22, 2013, 12:35 PM
USA
Joined Jan 2002
Thanks for the correction. I know they had the unbalanced 2s preset, but nothing larger than 2s could be changed w/o the balance lead.
I know Tim said they would look at allowing 2s unbalanced storage discharge, but I don't know if that was ever implemented. Any word on whether the DPL8 will allow that?
Old Nov 22, 2013, 02:08 PM
Seattle
Joined Sep 2007
That scenario wasn't addressed in the DPL. However, it can be done on any Powerlab today. Start with the unbalanced preset. On the Discharge tab, change the "Store Chg or Dsch" from NO to YES>. Change the discharge voltage to 3.83v. Change the charge voltage to 3.86v. That will give an unbalanced storage preset for up to 2s.
Old Nov 22, 2013, 03:35 PM
USA
Joined Jan 2002
Thanks, I've never seen that solution mentioned before. More proof you learn something new everyday!
Discussion Balance taps for PL8 K.B. Batteries and Chargers 6 Apr 07, 2013 11:50 AM
Discussion PL8 balance charge TP packs with two balance leads MikeAnderson FMA Direct 2 Feb 07, 2013 09:38 PM
Discussion PL6 vs PL8 - Node only charging viperman3 FMA Direct 13 Sep 06, 2012 10:20 AM
Discussion Will my PL8 charge a 2 cell pack that has no balance tap? WBFAir FMA Direct 7 Jul 05, 2012 12:39 AM
Discussion Can I charge lipos on a Nimh charger if I charge them through a balancer Max Powers Batteries and Chargers 9 Dec 23, 2008 06:28 PM
