Old Aug 28, 2010, 10:45 AM
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Would this work?
Would it be possible to run 2 ESCs off one single receiver channel via a Y-cable? I don't need the two ESCs to run independently and don't intend to use the BECs. Attached it a modified diagram from Ghost 2501's thread.
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old Aug 28, 2010, 11:01 AM
Semper Fi
GreenAmphibian's Avatar
Northern Triaid North Carolina
Joined Jun 2008
Yes, you can as long as you want both of them doing the same thing. I have done this in my S-100 for the outboard motors with the center motor and ESC being on another channel.
GreenAmphibian is offline Find More Posts by GreenAmphibian
Old Aug 28, 2010, 11:12 AM
RC sub dude
Joined Nov 2004
Thanks for the reply! What worried me was that some diagrams featured a "mixer" circuit that connects both ESCs with the receiver, but I guess that's if you wanted to get independent control of both ESCs. I wasn't sure if a Y-cable would work but it seemed logical since the ESCs sorta behave like servos in terms of getting the receiver signal input.
Old Aug 28, 2010, 12:52 PM
Joined Jun 2008
I have done this with a 4x4 rustler I built,use two same esc's though as performance of diffrent esc's are diffrent.Couldnt you use a Traxxas evx for the e-maxx?
redlined_b16a is offline Find More Posts by redlined_b16a
Old Aug 28, 2010, 04:59 PM
Rochester,NY
Joined Apr 2007
be sure to check the info on the esc, usually you need to disconnect a wire on the esc reciever plug to disable the bec. if you use a reciever battery you would need to disconnect that wire on each esc. Greg
Greg W is offline Find More Posts by Greg W
Discussion How would this BL motor work in an EZ*? beginner4life Beginner Training Area (Aircraft-Electric) 14 Jan 02, 2010 07:26 PM
Help! would this work? chessmaster Electric Ducted Fan Jet Talk 12 Nov 26, 2009 12:18 AM
Question New to electric, would this work? cargomaster Power Systems 13 Nov 21, 2009 05:25 PM
Discussion Charging multiple lipos - would this work? upp Batteries and Chargers 3 Nov 04, 2009 02:24 AM
Discussion Would this work? Greybird Large Electric Helis 20 Aug 28, 2009 05:06 AM
