Old Feb 14, 2010, 11:37 AM
Joined Feb 2010
which is the faster model?
comparing these two completely different models: starmax f18 90mm and freewing f35 360 tv on these setups ....which will be the faster model in the air on a level pass?
starmax f18 90mm : on stock setup and 5s 5000mah 30'c (keep in mind that the stock uses 6s 3700 25c lipos)
freewing f35 70 mm 360 tv: on js1400 motor/ 5s 3600mah 30c lipos
estimated top speeds of each?
appreciate the input guys....
walkingonair69 is offline Find More Posts by walkingonair69
Old Feb 14, 2010, 11:52 AM
Team White Llama!
gundamnitpete's Avatar
Having never seen the freewing f-35, I'd think it would be faster.'the js1400 on 5S will be about 2000watts.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 14, 2010, 05:36 PM
Joined Feb 2010
thanks for the reply gundamn, I was also wondering how much runtime do you think i would get with 5s 3300mah 30c lipos on a js 1400/wemotec 70mm?
Old Feb 14, 2010, 06:57 PM
Team White Llama!
If you ran WOT, under 2 minutes. With throttle management, I could see 3-4 no problem.
Old Feb 14, 2010, 09:02 PM
The Sloppy One
J03yT's Avatar
Va Beach VA.
It may be a close call on the speed. My buddy at the field had the V1 90mm F-18 on 5s and it was faster than anybody thought it would be. It was holding its own against a P-60 turbine powered Boomerang. He went to 6s which proved to be a bad idea. It gave up 2000watts.....just before, while on the bench, the fan exploded and went through his brand new castle 110.
But on 5s it was somewhere near or in triple digits.
J03yT is offline Find More Posts by J03yT
Discussion which is faster a reef racer or mini rio ? mortonj69 Racing Boats - Electric 2 Feb 09, 2010 10:10 AM
Discussion Which model to get? todd.lattimer Slope 9 Jan 30, 2010 08:49 PM
Discussion Which are faster Phenom01 Electric Plane Talk 30 Dec 26, 2009 10:12 AM
Which is faster? adamkhwaja Foamies (Kits) 3 Apr 09, 2002 11:58 AM
Which faster... kepople Electric Plane Talk 1 Jul 06, 2001 01:13 AM
