View Poll Results: Which do you use?
Magnetic 8 18.18%
Pins/wood or steel angles/glass 38 86.36%
Multiple Choice Poll. Voters: 44. You may not vote on this poll
Old Jan 23, 2009, 10:14 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Poll
Magnetic building boards
Recently we've seen an explosion of magnetic building boards. I've been magnetic since getting back into building several years ago, and each day I see more and more people building with magnets, not pins. So, a poll:
1 Do you use a magnetic board exclusively?
2 Do you use both magnets and pins?
3 Do you use pins only?
4 Do you plan to try a magnetic board in the future?
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jan 24, 2009, 12:03 AM
President @ Hemet Model Master
huggie9999's Avatar
United States, CA, Hemet
Joined Oct 2006
Geoff. put me down for #3
huggie9999 is online now Find More Posts by huggie9999
Old Jan 24, 2009, 12:17 AM
a.k.a Maltone
Australia, NSW, Goulburn
Joined Jan 2005
Geoff - I'm pins only.
I'd like to try a magnetic thingy at some stage.
Pat
Pat Lynch is online now Find More Posts by Pat Lynch
Latest blog entry: A New Year's Project
Old Jan 24, 2009, 12:46 AM
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
I do much of my building with 1-2-3 blocks. They are machined steel blocks which are exactly 1" x 2" x 3". As you would expect they are quite heavy so they do a good job of holding stuff down. They also have perfect right angles and can be used to hold things in vertical alignment. Butt two of them together to make a perfect jig for gluing things together at perfect right angles. I can hardly build without them any more. Beyond that I usually build on glass and tack glue right to the surface.
Chad Veich is online now Find More Posts by Chad Veich
Old Jan 24, 2009, 02:15 AM
CaptAhab's Avatar
United States, TX, Houston
Joined Sep 2007
magnetic board exclusively per http://www.airfieldmodels.com/inform...oard/index.htm
CaptAhab is offline Find More Posts by CaptAhab
Old Jan 24, 2009, 06:37 AM
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
pins , ceiling tile and squares for me ( #3 )
jofrost is offline Find More Posts by jofrost
Old Jan 24, 2009, 08:31 AM
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
I've just started using a magnetic building board. The airfield models link in CaptAhab's post is the best source of info I've found.
Mark Wolf is offline Find More Posts by Mark Wolf
Latest blog entry: Stevens Aeromodel Skybuggy 100
Old Jan 24, 2009, 09:53 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I'm still "stuck" with pins to the past. I do use CYA glue and accelerator, brushless motors and lipos and iron-on coverings including Doculam. I use mostly TLAR and "imitation" technology and only read about magnetic building boards, incidence meters, wing jigs, CAD programs and hobby software, etc. Maybe that's why some of my creations have banana-fuselages and fly funny.
E-Challenged is offline Find More Posts by E-Challenged
Old Jan 24, 2009, 09:55 AM
North East England
Joined Feb 2004
I'd never even heard of magnetic building boards!!! I doubt I'd use one though - there's something very satisfying about hammering pins into a wooden board
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Jan 24, 2009, 10:16 AM
Balsa for me, thanks.
irish_lord99's Avatar
Yalova, Turkey
Joined May 2007
I'm definitly a #1! I used to use a board and pins, but I started using magnets and I'll never go back. I built a set of jigs like the previously mentioned ones at airfieldmodels.com and are the best building tools in my shop bar none. Magnetic jigs are better than anything I've seen for building a straight fuselage and for aligning wings and tail surfaces.
The only drawback I can see is the price, but I got all my latch magnets from www.allelectronics.com and all my block magnets from a local vendor. When it was all said and done I doubt if I spent more than $100 on the whole thing.
I'm currently using them to build this: http://www.rcgroups.com/forums/showthread.php?t=979220
~Jake
irish_lord99 is offline Find More Posts by irish_lord99
Old Jan 24, 2009, 10:22 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Same here.
DanSavage is offline Find More Posts by DanSavage
Old Jan 24, 2009, 11:14 AM
Got Epoxy
shrub wacker's Avatar
Salisbury Ma
Joined Dec 2004
Good o'le Pins and 2' x 4' ceiling tile for me as well
Glenn
shrub wacker is offline Find More Posts by shrub wacker
Old Jan 24, 2009, 11:17 AM
Joined Aug 2006
#2. some things you need to pin. or clamp. but the magnets are best for laying out the project.
phoran is offline Find More Posts by phoran
Old Jan 24, 2009, 11:41 AM
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Currently I use board, pins, clamps, and boxes of .45 cal & 9mm bullets. I've been intrigued by the magnet set-ups, but have wondered about some springy sticks pushing magnets about when they try to resume their natural shape! I realize some of the rare earth magnets are quite powerful, however.
What do most people use as a base?
James
Deuce is offline Find More Posts by Deuce
Old Jan 24, 2009, 12:15 PM
LtDan's Avatar
Northern CA
Joined Mar 2006
Magnets all the way. I have two boards a short one for Fuse building and a long one for wings. We a great metal supply store here in Sacramento and I can buy sheet steel and have it sheared to size. I screw it to 1-12 pine. Airfield models has the addie for the magnets.....
LtDan is offline Find More Posts by LtDan
Foam Building Boards 3Wheels Electric Plane Talk 5 Dec 14, 2002 08:31 AM
Wright Engineering's building boards Scott C The Builders Workshop 4 Oct 21, 2002 12:59 PM
Beware of Great Planes Magic Magnetic Building Board System Red Baron 47 Electric Plane Talk 8 Jul 19, 2001 10:24 PM
