Old Apr 22, 2005, 03:05 PM
Norway
Joined Apr 2005
Jeti 30 3P and lipos
Ive got one Jeti30 3P speedcontroller which ive until now have used nimh batteries on. Im now planning to use Lipos. Can I do this? On jetis webpage its only metioned Nicad/Nimhs in connection with this speedcontrollers. I see they also got some meant for lipo-use..
spirit100 is offline Find More Posts by spirit100
Old Apr 22, 2005, 04:45 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
CAN you use it? Of course you can.
SHOULD you use it? That depends on your battery choice and your flying habits.
If you are planning to use a 2s lithium battery of some sort you'll be fine - just don't restart the motor too many times after the LVC engages. If you're planning to use 3s or 4s, then much more care is required. A third-party add-on LVC for lithiums (such as the FMA AVC1AIR) would be highly recommended.
BEC is offline Find More Posts by BEC
jeti 30-3p servo connection???? buckeyes1997 Power Systems 2 Jul 12, 2002 09:01 PM
FS: Mega 22/10/5 BL motor and Jeti 30-3P Esc Rudderman98 Aircraft - Electric - Airplanes (FS/W) 7 May 30, 2002 01:33 AM
impedance for Jeti 30-3P ESC? joey221 Power Systems 0 Apr 16, 2002 12:41 AM
Help! Jeti 30-3P controller cutting out! Megowcoupe Power Systems 31 Oct 29, 2001 09:35 PM
Jeti Phasor 15/4 and Jeti 30-3p parrott Aircraft - Electric - Airplanes (FS/W) 8 Oct 26, 2001 05:56 AM
