Old Aug 15, 2014, 10:28 AM
Joined Oct 2013
Noob Troubleshooting - Quad Pitches in wrong direction
Hey All,
I am building my first quad. I went outside and put it at 10% throttle, so it was just barely not lifting off, then played with the various inputs to see that the correct motors spun faster. Unfortunately they did not.
Correct:
Yaw Stick Left --> CCW rotation of quad
Yaw Stick Right --> CW rotation of quad
Roll Stick Right --> Left side motors lift into the air
Roll Stick Left ---> Right side motors lift into the air
Throttle Stick Up --> Everything moves faster
Wrong:
Pitch Stick Forward --> Front motors lift into the air
Pitch Stick Backwards --> Back motors lift into the air
Flight Controller: CRIUS AIOP V2.0
Firmware: MegaPirateNG 3.0.1
Ground Station Software: Mission Planner 1.3.7
FRAME_CONFIG: QUAD_FRAME
FRAME_ORIENTATION: X_FRAME
Motor Connections and Prop Rotation Direction: According to http://xxl-modellbau.de/abbildungen/...gaPirateNG.pdf page 42
I tried recalibrating the accelerometer using mission planner (no effect). Using Mission planner I have confirmed that pitch stick right increases pwm, pitch stick left decreases pwm.
I suppose I can just flip the pitch channel in my transmitter, but can anyone tell me what I did wrong / the reason this is happening?
treerobber64 is offline Find More Posts by treerobber64
Old Yesterday, 01:14 PM
Joined Oct 2013
bump. Any ideas?
I tried flipping the pitch channel and I am now able to fly it. Although it tends to drift in the forward direction slightly all the time.
Old Yesterday, 03:08 PM
Watching EKRAN
Joined Jul 2013
Originally Posted by treerobber64 View Post
bump. Any ideas?
Uh, you solved it then.
Calibration issue? (gyro/accel) Have you tried correcting with trims?
Which frame is it? (CoG might affect it?)
varis is offline Find More Posts by varis
Sold Custom Direct Drive Variable Pitch Tail for 450 Pro navigator2011 Aircraft - Electric - Helis (FS/W) 3 Nov 04, 2013 01:38 PM
Discussion Quad flies normal but flips ony when rudder or yaw is used in one direction - why? hamsterchaos Mini Multirotors 0 Oct 11, 2013 05:04 PM
For Sale Custom Direct Drive Variable Pitch Tail for 450 Pro navigator2011 Aircraft - Electric - Helis (FS/W) 3 Oct 08, 2013 06:26 PM
Help! Why is the blade pitching the wrong direction? upa123 Micro Helis 5 Oct 14, 2010 11:44 PM
Gyro working in wrong direction! Something wrong? larsen2000 Electric Heli Talk 1 Jul 26, 2005 01:53 AM
