Old Jun 01, 2014, 11:16 AM
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
AS3X and Corrosion-X??
I've been out of the water for about a year. Spent a lot of time flying helicopters last year. I went out to the lake last week and had a blast. I got a new CZC and I ordered a Sport Cub too both with floats.
Has a verdict been reached yet on the use of Corrosion-X with the AS3X equipped receivers? Will the sensors work ok after they've been treated?
-J
CyberJay is online now Find More Posts by CyberJay
Old Jun 23, 2014, 08:33 AM
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
Well, since I got no replies I figured I'd put a post here for others. I treated the AR635 in my Carbon-Z Cub and there were no ill effects at all. Remember with AS3X the receiver needs to be positively connected to the airframe, so I suggest removing the case, treating the board only, and then carefully re-installing the case without getting any corrosion-x on the case. That way you can use 3M double sided tape to attach the rx to the airframe.
-J
Old Jun 23, 2014, 09:00 AM
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Good to know. Thanks for trying it out for us.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
For Sale AR635 6-Channel AS3X Sport Receiver and 4 x E-flite EFLR7145 Digital MG Mini Servo ap_rpm Aircraft - General - Radio Equipment (FS/W) 5 May 25, 2014 08:30 PM
Sold parkzone um t-28 with as3x gyro and 2500kv bl motor, 2 x 2s 200mah IceRain29 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Nov 10, 2013 01:19 AM
Sold parkzone um t-28 with as3x gyro and 2500kv bl motor, 2 x 2s 200mah IceRain29 Aircraft - Electric - Airplanes (FS/W) 2 Nov 10, 2013 01:12 AM
Discussion nCP X, mCP X [BL] or 130X w/ AS3X and SAFE? fryfrog Micro Helis 0 Jul 26, 2013 10:35 PM
