Old Aug 18, 2012, 07:14 AM
United States, TN
Joined Mar 2011
Seeking 55" Plus Planes That Have Lot's Of Ground To Prop Clearance
I fly off of a rough grass runway that is not always trimmed. Take offs and landing are sometimes an adventure because of the prop and gear catching the grass especially if the grass is damp. I'm looking for receiver ready (or nearly so) tail dragger planes that have good ground clearance. I like planes in the 55" wingspan plus category, an extra inch or two of ground clearance makes all the difference. Any recommendations greatly appreciated.
Thank you!
itsme2 is online now Find More Posts by itsme2
Old Aug 18, 2012, 08:45 AM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
PRC (People's Republic of Commiefornia)
Joined Jul 2005
Multiplex Fun Cub is ideal for your field conditions.
http://www3.omnimodels.com/cgi-bin/w...I=MPUA2242&P=7
http://www.advantagehobby.com/208252/MPU264243/?cat=187
And of course any Easy Star style model with a high mounted rear pusher motor.
Doubletap is offline Find More Posts by Doubletap
Old Aug 18, 2012, 09:00 AM
United States, PA, Lansdale
Joined Feb 2012
Hi Itsme2,
The FMS J-3 Cub, 1400mm wing span is a wonderful flying plane. Lot of ground clearance. It weakness is its landing gear. Rough landings will stretch the spring, if not breaking some plastic part. Can be beefed up using wire between certain stress points. You could even take the wheels and undercarriage off and get aluminum landing gear with really big wheels. It is available from Banana Hobbies at a very good price. (ARF or RTF)
Frank Arbaugh
arbfrank is offline Find More Posts by arbfrank
Old Aug 18, 2012, 09:01 AM
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
The funcub has clearance but the stock landing gear is very springy and you could end up cutting the lawn with it.
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Aug 18, 2012, 10:48 AM
Joined Nov 2006
Multiplex Mentor. A sixty-three inch wing that is easily removable for transport and more prop clearance than you will ever need. Slows down on final easily and works very well on unimproved landing sites. Great ground handling, too.
Fravits is offline Find More Posts by Fravits
Old Aug 18, 2012, 02:10 PM
United States, TN
Joined Mar 2011
Tower Hobbies is the only one that comes up as selling a receiver ready Multiplex Mentor but they have it listed as "Discontinued". Does anyone here know of another source?
Thank you!
Old Aug 18, 2012, 02:14 PM
United States, TN
Joined Mar 2011
Will an Easy Star style model take off from a grass runway or do they have to be hand launched?
Old Aug 18, 2012, 11:04 PM
Doubletap's Avatar
Joined Jul 2005
Yes, most EZ style models have enough thrust to ROG, but why would you want to do that when all they need is an easy over hand toss for a launch?
Old Aug 19, 2012, 07:20 AM
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
Thank you!
Get whatever plane suits your fancy, then swap out the motor to a higher-Kv motor so you can use a smaller-diameter prop.
herk1 is offline Find More Posts by herk1
Old Aug 23, 2012, 12:59 PM
Tucson
Joined Nov 2009
Most tail draggers at 55 inches will clear an electric prop on grass, if the grass is decently cut. What you need is bigger wheels (3 inches and bigger) on the front gear, so they will not dig into the grass.
Clipped wing Cubs, Cubs, Beavers, electric "Ugly Sticks" -- all sorts of tail draggers will fly off grass. The SeaGull 66 inch Decathlon with a 50-55 700 kv motor and 15 inch prop flies wonderfully off grass with 4S power. Or the SeaGull SpaceWalker. The DeNight Special with wheel pants and a 1500 watt 700 kv motor flies nicely off grass (but lands fast).
The key is big tundra whacker front tires, and at least a 1500 watt motor at 600-700kv.
Or a leadershobby power 46 at 2,000 watts and 700 kv, on 4S voltage.
The real challenge is avoiding the sprinklers when they turn on! That will teach you precision landing skills!
wuest3141 is offline Find More Posts by wuest3141
Wanted seeking for a Range Video Ground Station cabecinhas FPV Equipment (FS/W) 1 Aug 19, 2012 10:40 PM
For Sale Spider quad / FlyingRobot-550 folding frame plus extras/ lot of esc's even simon k TheOne420 Aircraft - Electric - Multirotor (FS/W) 3 Jul 13, 2012 11:45 AM
Discussion Camera system that can track plane from ground? CrazyJB Electric Plane Talk 12 Mar 16, 2012 12:56 AM
Discussion Prop Ground clearance issues eran_k Glow to Electric Conversions 9 May 12, 2006 04:10 PM
TM400 Prop Ground Clearance ? Rob_P GWS (Grand Wing Servo) 2 Oct 25, 2005 08:24 PM
