Old Mar 09, 2005, 05:14 PM
Rocket Surgeon
intermision's Avatar
Sugar Land, TX
3 blade props
Who makes a 3 bladed prop besides GWS?
intermision is offline Find More Posts by intermision
Old Mar 09, 2005, 05:56 PM
It's me Glacier Girl
Joined Aug 2004
Master Airscrew makes a few, and I bet so does APC.
SHELBY1 is offline Find More Posts by SHELBY1
Old Mar 09, 2005, 07:52 PM
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
The Master Airscrew ones are great -- I bought several for my P-38, and I love them!
They're not so great on belly landers though...
Check out this web site -- http://www.hobbypeople.net/mfr/WINDSR01.asp
Red 61 is offline Find More Posts by Red 61
Old Mar 09, 2005, 08:05 PM
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
Red - Did you buy one pusher and one puller prop to get counter rotating???
Matt
Willmsy is offline Find More Posts by Willmsy
Old Mar 09, 2005, 08:39 PM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Flying styro has a fantasting 9x7 through hobby lobby that's specificly designed for electric.
rdeis is offline Find More Posts by rdeis
Old Mar 09, 2005, 08:45 PM
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Variable Pitch 3 Blade Prop
Vario Prop, check e-flightline.com they have them. The pitch can be adjusted to reach the peak performance of your motor on a bench test, then flown. Very cool, I have a 4 and 3 blade kit.
Chris
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Mar 09, 2005, 08:49 PM
MondoMor's Avatar
Rogers, MN. USA
Joined Mar 2003
MetroGTi used some Tornado props on his Molt P-38. They seem to work well, plus he was able to find pusher and tractor props so he could have contra-rotation.
MondoMor is offline Find More Posts by MondoMor
Old Mar 09, 2005, 09:39 PM
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
C of G I have been looking at the Vario Props.. My biggest concern is if they will work with the radial mount of the Axi motors???
Anyone know the answer to that?
Matt
Old Mar 09, 2005, 10:30 PM
Callsign: CornDog
HawkLover's Avatar
Milpitas, CA
Joined May 2003
I beleive the Master Air screw 3 blade props can be purchased for clockwise and counter clockwise rotation.
HawkLover is offline Find More Posts by HawkLover
Old Mar 10, 2005, 08:42 AM
Outcast outlaw
Joined Aug 2004
Yep -- that's exactly what I did.
Old Mar 10, 2005, 01:25 PM
Outcast outlaw
Joined Aug 2004
I went home for lunch today, and took a look at what I have on my bench...
I have two, unopened, unused Master Airscrew 9x7 3-blade props -- one is a pusher, and one is a puller (counter rotating).
If you're interested, I'll sell them to you cheaper than the best price you can find (probably www.hobbypeople.com).
PM me if you're interested.
Old Mar 10, 2005, 09:11 PM
Joined Feb 2004
Matt
Yes it will work fine, just match the 3mm shaft size(or whatever the motor you want to use) to the selection of hubs from Vario. I have fit it to an MPJet gear box, MPJet outrunner, Axi 22/12/20, and so on. The hub is almost twice as thick as a prop so you will have adjust for that and spinners are a custom deal. Somewhere I posted pics of my Alfa P51 with the install in the park flyers section.
Chris
Old Mar 10, 2005, 10:16 PM
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
C of G - http://www.hobby-lobby.com/brushless-axi2814.htm
Look at the bottom of this webpage. The Radial mount set comes with a prop adaptor, however I don't see what size it is and it is threaded.
Matt
Old Jul 11, 2005, 03:16 PM
Joined Feb 2004
You have to use the shaft on the other side of the Axi or a GWS prop adapter for the Axi which Hobby Lobby sells as well I think, I bought one but cant place from who.
Chris
Old Jul 11, 2005, 04:06 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
I'm 100% with CofG... VarioProp. Fantastic little devices. Sure, the hub is a little pricey, but you have a wealth of blade options and the blades are cheap and replacable. I even got more blades for mine in the mail today
I have 3 and 2 blade hubs.
Here's some pics I took last night ...
theKM is offline Find More Posts by theKM
Where to buy small 3-blade props shv2sail Power Systems 7 Mar 05, 2003 03:31 PM
2 or 3 blade props jsomers1234 Power Systems 42 Nov 30, 2002 05:56 PM
GWS 3-blade props now avalible @ Canadian Model Supply Paul Penney GWS (Grand Wing Servo) 3 Nov 19, 2002 02:53 PM
3 blade props? Battfly Power Systems 2 Nov 30, 2001 10:23 AM
3 blade props Dave Seay Scale Kit/Scratch Built 12 Nov 29, 2001 12:07 PM
