Old Jul 28, 2014, 02:59 PM
Tucson, Az
Joined Feb 2007
FBL conversion EXI PRO Carbon ??
I bought this a couple years ago. Comes assembled but need to take aprt to use locktite. Never started abd woimdered if anyone converted to FBL ? I'm not looking for 3 d wonder but decent. Have some EXI m/g servos/ 40A eac/ etc.
FBL unit unsure. Just wondered about any conversions that work ? Thanks a bunch/ Dan
dankar04 is offline Find More Posts by dankar04
Old Jul 28, 2014, 03:05 PM
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Yep , mine are EXI and HK 450pro. All you need is the align dfc head and shaft or the HK dfc or other with swash followers . I have both and like the HK ONE better because it comes with the swash for 24.00 .
jombo is offline Find More Posts by jombo
Old Jul 29, 2014, 01:39 PM
Tucson, Az
Joined Feb 2007
Thank you for reply, Any links on these items ?
Old Jul 29, 2014, 02:16 PM
AMA# 548800
jombo's Avatar
Joined Dec 2007
Sure
http://www.helidirect.com/align-trex..._1313_1365.hdx
There is no swash with this one , just a main shaft, and head, links ,arms . I am not sure if the feathering shaft is there either . I think I still have one in the package I can check .
HK sells a few different units
http://www.hobbyking.com/hobbyking/s...ex_450PRO.html
Then this ,no swash
http://www.hobbyking.com/hobbyking/s...ashplate_.html
Then with the swash
http://www.hobbyking.com/hobbyking/s..._Assembly.html
They all do the same thing so it's just a preference of which you like best .
I have all 3 , align , HK DFC swash included and the non DFC. All fly the same .
Old Jul 29, 2014, 11:43 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
http://api.viglink.com/api/click?for..._Assembly.html
this is the one I put on my EXI PRO!! seems too be working well!
whiskykid is online now Find More Posts by whiskykid
Latest blog entry: heli's
Old Jul 30, 2014, 01:55 PM
Tucson, Az
Joined Feb 2007
Thank you guys/ H/K unit looks fine. Anybody try Robird FBL unit ?
Old Jul 30, 2014, 03:20 PM
AMA# 548800
jombo's Avatar
Joined Dec 2007
My ROBIRDv1 I had tail problems. I could of updated it but went with the other kbar. Mine is in the box
Old Today, 03:24 AM
Tucson, Az
Joined Feb 2007
I just recieved an extra V450D01 V2 RX.. Now with a FBL conversion this RX should work. Servos need to retate using this RX as you can not revese any with TX. If you do gyros go bunkers.
Discussion EXI Pro Carbon kit ? dankar04 Mini Helis 4 May 13, 2014 10:02 AM
For Sale REDUCED!!!LIKE NEW!!! 500 EXI Carbon Pro w/Hughes 500 Scale Fuselage Kevin Greene Aircraft - Electric - Helis (FS/W) 6 Feb 03, 2014 07:15 PM
Discussion Exi pro carbon 450/ servo ? dankar04 Electric Heli Talk 0 Oct 27, 2013 01:29 PM
Discussion CopterX CX450 Pro V3 FBL or EXI 450 Pro nascar1929 Mini Helis 4 May 07, 2012 12:48 AM
For Sale EXI Carbon edition fbl conversion artf bada61265 Aircraft - Electric - Helis (FS/W) 6 Apr 17, 2012 04:09 PM
