Old Jul 20, 2014, 01:49 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Build Log
Pak Fa - Full Fuse Pusher: Try and Error Approach
I tried to draw up plans for a PakFa already end of 2012. February last year, I just did quickly a 50 % proof of concept build. Since then, I did not do much about flying or building.
So two weeks agou, when my 8 year old son stumbled into my hobby room, he picked up the PakFa and wanted to throw it around. But first I needed to balance it.
What eventually happened: We did gliding/gc tests, just for fun.
RC Pak Fa Glide Test (0 min 50 sec)
lessram is offline Find More Posts by lessram
Old Jul 20, 2014, 01:56 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
First Session
So somehow I got the bug. I will build a 100 % version, but I have to play it by the ear.
I have no clue, how to link the control surfaces, where to put the controller, .... so I will take it step by step. The concept I want to follow:
Just building small components, and in the end, it should be just one big puzzle.
My component list:
- nacelles
- front part bottom
- front part top
- turtle deck
- nacelles (upper part)
So last week, I started with just putting most of the components together
Instead of cutting bevels, I just glued in the formers at the correct place, and then was just able to sand the bevel with a sanding block.
Eventually I was surprised, how far I got.
Latest blog entry: F/A-18 Mk II
Old Jul 20, 2014, 02:02 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session two
So today, I worked some more on the Pak Fa.
Highlight: The nose. It took me longer than expected, but eventually I was happy with it.
Old Jul 22, 2014, 03:57 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session three
This time, working on the upper part.
This included cutting, glue and sanding the "upper" nacelles.
My original idea to form the sides went down the drain, since the first part I wanted to bend, just broke.
So I just "doubled" up the front section of the nacelle, but as a side effect, I had no problems to sand it into shape.
The next challenge was to cut out the inner shape of the nacelle out of the turtledeck.
All in all, I'm quite happy so far.
But, I really need to think about the control surfaces - how to connect them. On the outside or via linkage on the inside
Not sure yet. Any comment is welcome !
Cheers
Olli
Old Jul 23, 2014, 01:51 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Nice workmanship! What's going to propel it, or will it soar?
djacob7 is online now Find More Posts by djacob7
Old Jul 23, 2014, 03:00 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Thanks. It will be a pusher.
I don't think the 100% will be soaring as well as the 50% !
The surface will double("lift"), but the weight will triple. Not that I expect it to be a flying brick - like my avatar
Old Jul 23, 2014, 04:11 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session four
Today, I cut out the rudders
Nothing really special, but I had to tinker about the base of the rudders. Took me some time to figure it out, what to glue and how to sand it.
Result is ok.
Next steps: Dremel the elevators. Then it really gets to installing servos, motor, ... and glue the different pieces to one Pak Fa.
Question: I like to paint it like the 055 (see pic). Does anyone know what color they used ? Depending on the pictures I found or articles I read: It's light/dark blue or gray
Old Jul 23, 2014, 10:33 AM
Germany, SN, Dresden
Joined Nov 2008
Hi lessram,
interesting project.
To choose the right colour, have a look at http://www.mars.slupsk.pl/fort/sukhoi/default.htm
This site is my favorite place to look for colour schemes.
Torsten288 is offline Find More Posts by Torsten288
Old Jul 23, 2014, 10:29 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Perfect Torsten !
Excactly what I've been looking for.
"Ein herzliches Dankeschön" to the north
Old Jul 24, 2014, 08:14 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session five: Dremel time
Today was a Dremel day.
Finally I decided to link the ailerons "internally" through a big "Z bend" (or whatever you call it in English). Also dremeled the elevators for the carbon spar. Took me a while to figure out how to place the pieces. Another annoying thing: Setting the depth of the milling head. Half a mm up - no too much - a notch down .....
Except of the cockpit, I don't know what to "construct" anymore. So it is nearing the point, where I have to install the electronics and begin to glue the pieces
Old Jul 24, 2014, 02:25 PM
Parkjet collector
Wobisch's Avatar
Schweiz, AG, Merenschwand
Joined Oct 2011
well done Lessie. Nice to see that you make fast progress!
While I have my foots in the pool I read your thread.
Wobisch is offline Find More Posts by Wobisch
Latest blog entry: FlyFly Mirage
Old Jul 25, 2014, 03:53 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session six: Control surfaces
Hey Wobisch
Enjoy your well earned holiday. Not yet eager to come back and put some planes into the air ?
Control surfaces was the theme of today. Where exactly to place the servos, esc ....
One problem I encountered: Since the esc will be placed in the middle of the plane, no airflow there. So I places some air- diverters in front of the serveros to push some air in, and I hope that Bernoulli will suck it out. If it will be enough, we'll see.
Rest is more or less straight forward.
Cheers
Old Jul 26, 2014, 11:21 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session seven - A: last steps of production
I'm more or less finished with building the different pieces. Most problems I had with the cockpit. (I hate sanding cockpits). I screwed up my first attempt with the traditional layering of pieces.
For the second attempt, I just got the Gripen cockpit out or the waste bin and modified it. I'm not really happy with the final outcome, but if I sand some more on it, I have to place back into the waste bin again.
Now is time to move to the assembly line.
Old Jul 26, 2014, 11:30 PM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session seven - B: Assembly
I was eager to start with the assembly:
First problem: How to glue the hinges. Eventually I cut small slits into the wing, so I could peel back the depron. Result: No epoxy mess all over the hinges.
By the end of day - ailerons and elevator glued in.
Second problem: elevator does not move. Somehow, epoxy got between the rod and tube. Now I have to figure out, what to do ....
Not a good start
Old Jul 29, 2014, 04:11 AM
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Session eight: Servos and bottom part
Glue in the tube:
My thoughts, it must be near the end of the tube and realized it happened while gluing the elevator servo arm. So I just "dremeled" 5 mm of the tube away and that was it.
Then I first installed the servos and linked them. During this work, I was thinking about how to optimize the airflow over the ESC. So I put in some formers to guide the air over the ESC. If it helps ? No clue, but I feel better
Eventually it was time for assembly:
First the nose part and motormount, then the huge bulk with the nacelles and the middlepart. Took me 20 minutes just to prepare everything with UHU por.
Let everything dry out over night.
For Sale LX Lanxiang 70mm Fans with 6B rotors from PAK-FA T50 IntheTubeDeep Aircraft - Electric - Jets (FS/W) 0 Jul 16, 2014 07:17 PM
Discussion America: End of an Error Approaches Dusty Puddles Life, The Universe, and Politics 51 Jan 18, 2009 10:42 PM
A battery pak you might want to try............ HankF Electric Heli Talk 13 May 29, 2001 08:20 PM
