Old May 30, 2014, 01:50 PM
United States, SC, Columbia
Joined Apr 2012
Nice looking bird! How much of the fuse did you have to cut off to accommodate the cowl?
radams11 is online now Find More Posts by radams11
Old Jul 29, 2014, 05:12 PM
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
The .61 Escapade continues to amaze me. Am breaking in an NGH GT17 gasser on it. Went to the field this morning. Cold front came through so great for the break-in.
Second flight heard a buzz then the rudder was dangling from the pushrod clevis 200 feet up in the air. Totally separated from the fin. The .61 kept flying like nothing had happened. No trim change. Came in for a normal landing but no ground steering after roll out. Reminded me of a WWII bomber landing with its tail shot off.
Examination of the fin and rudder showed all the CA hinges are still in the fin. None are broken but all are de-laminated. The fuzzy outer layers that accept the thin CA is stripped off leaving only the stiff inner plastic layer sticking out of the fin. The tail wheel wire is pulled out of the rudder but that is understandable considering the total separation of the rudder from the fin.
That is it for me and CA hinges in large fuelers. I have a pack of Robart medium hinge points and they are going to replace the CA hinges in the .61 rudder.
But I am still amazed at how the .61 didn`t even notice it had no rudder. That huge Escapade fin saved the day.
Bill
erie_flyer is offline Find More Posts by erie_flyer
Old Jul 29, 2014, 05:26 PM
I want just one more plane!
timwj1's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
Good for you and your plan Bill, I'm glad if something like that is going to happen, it happens in a plane that just likes to fly and therefore live to fly another day. Good point that I should tug on all my CA hinged control surfaces from time to time to make sure they are still attached solidly.
timwj1 is online now Find More Posts by timwj1
Old Jul 30, 2014, 10:24 AM
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Better to lose your rudder than your elevator. My standard Escapade was flying breaking in my new Evo 10 gasser when the elevator began to flutter and broke the elevator clevis. I was able to slow down a bit and "land" somewhat level, but the Escapade was totaled. Evo 10 survived just fine and it's up and flying in a new Spacewalker II.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jul 30, 2014, 08:25 PM
timwj1's Avatar
Joined Feb 2013
McD, do you think your elevator issue was the hinges delaminated also? How about too much gap in the hinge line? I'm now wondering with another year of age is I need to re-hinge my control surfaces? Typically I use great planes ca hinges, not the ones that come with the plane, but it is a great planes plane.
Old Jul 30, 2014, 10:22 PM
kingsflyer's Avatar
Joined Sep 2005
No, the hinges were firmly attached and in perfect shape. The problem was too high air speed for the airframe caused the elevator to flutter. Even with the flutter, the elevator hinges didn't fail, the clevis pin broke off.
McD
Old Jul 31, 2014, 03:26 PM
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
The saga of my .61 Escapade continues.
Glued the rudder back on, no problem. Took it out yesterday. Three flights, no problem. Still breaking in the NGH GT17 gasser.
Went out this morning. First flight OK. Second flight all of a sudden needed a bunch of left aileron trim. Landed and checked it out. The Sullivan brass clevis on the left aileron pushrod had worn 1/8 inch of thread on the steel pushrod. The clevis was floating back and forth in this 1/8 inch being restrained by good thread front and back so the clevis never left the pushrod.
Came home and replaced the clevis and the pushrod.
The .61 Escapade is rated up to 15cc two stroke. I have been breaking in a 15cc RCGF, 17cc NGH and 20cc DLE on this plane, all gassers. Maybe the 20cc was putting too much strain on the control surfaces. There are a lot of flights on the .61 so it may be normal wear and tear as well.
Anyway, the .61 is a tough old bird. It lives on to fly another day.
Bill
Great Planes Escapade...has anyone flown? research_guy Beginner Training Area (Aircraft-Electric) 5 Aug 05, 2002 11:33 AM
Great Planes Escapade dave_lilley Electric Plane Talk 0 Nov 15, 2001 11:57 PM
Great Planes Escapade dave_lilley Site Chat 0 Nov 15, 2001 11:57 PM
Great Planes Escapade, a sweet little ARF! Paul Penney Parkflyers 9 Sep 18, 2001 10:13 PM
Great planes Escapade Paul Penney Foamies (Kits) 0 Sep 09, 2001 06:38 PM
