Old Dec 07, 2014, 02:53 PM
Joined Jul 2011
Originally Posted by Dogdude View Post
I got an original "Golden Eagle "EPP Eagle
Here:
http://www.freewebs.com/eppeagle/
I added ailerons to mine for a little more turn authority
Love flying it
https://www.youtube.com/watch?v=S8Q9ll0V5SA
https://www.youtube.com/watch?v=LpsnW0mHjP0
https://www.youtube.com/watch?v=Qy_g2l0z0mk
Oh and a little slope soaring
https://www.youtube.com/watch?v=3pevSKsPgwc
While it's a personal choice to ad ailerons, IMHO it's really not worth the effort, additional expense and extra weight.
When set up properly with the correct amount of down and right thrust, flying on High Rates, with only the V tail control surfaces, you are still able to do tight circles, inside & outside loops, inverted flight and rolls.
Check out this video - Only V tail - (all stunt maneuvers are from the 1/2 way point of the video)
DW Hobby Eagle ワールドモデルス EPP イーグル (3 min 16 sec)
stryker2 is offline Find More Posts by stryker2
Old Dec 07, 2014, 03:13 PM
Joined Aug 2012
Thanks guys, here's the set up and results
On 4S:
Propeller:
HK 9x5 Folding Prop and Spinner
http://www.hobbyking.com/hobbyking/s...idProduct=7844
ESC:
Unknown 40 amp
Battery:
4S Zippy Compact 25c (fully charged and balanced)
WOT Static:
250w 17 amps
On 3S:
ZIPPY Flightmax 2800mAh 3S1P 30C (fully charged and balanced)
http://www.hobbyking.com/hobbyking/s..._3S1P_30C.html
WOT Static:
145w 12.5 amps
Looking at the stats I think it's just a very inneficient airframe, climbs outs then gliding seems to be the way to go for flight duration, though the sink rate is pretty bad
Dogdude is offline Find More Posts by Dogdude
Old Dec 07, 2014, 03:23 PM
Joined Aug 2012
https://www.youtube.com/watch?v=GpVX1_1wPt4
Not being funny or derogatory but those "stunt manouvres" were more like "flopping around in the air with little control
I know it's "possible" to fly the Eagle adequately with just V-Tail you definately get more control authority with ailerons, it's down to the individuals to decide whether it's worth the effort or not, after all this is not designed as or supposed to be an aerobatic plane, it's for floating around and freaking the birds out , maybe some secret video work too
For me the ailerons allow me to fly in slightly more wind, but it still prefers low wind, it get's beaten up too much in strong gusts
Old Dec 07, 2014, 04:39 PM
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Same here, Dogdude. I myself installed ailerons on my Dancing Wings eagle. I've even programed a on and off ailerons to see the difference between both. -Using rudder for yaw and elevator for pitch.- ( However, I have also straighten the poly-hedral wing tips out and given it about 5 or 6 of dihedral. ) I noticed the handling is more crisp, where as the the tail only control is ..fine. It just depends on the person and their flying preferences.
G-LO is offline Find More Posts by G-LO
Old Dec 31, 2014, 12:04 PM
Joined Jul 2011
No offense taken .... I meant with only V tail one can still mimic a birds natural flight envelope quite effectively. It does not 'need' ailerons to fly well is all I'm saying!
The addition of ailerons will certainly open up the flight envelope allowing you do more unnatural bird flight characteristics and like you mentioned, probably allow you to fly in a little 'higher' wind with more control. That been said, from my personal experience these birds don't care for too much wind. (5mph or less is ideal!)
I would like to see this type of model come out with a completely different wing design. Perhaps a " Gull wing" design instead of a straight flat bottom .... something that could be done from any of the available kits with modification and some ingenuity. .... How well it would fly, is a whole other story!
Old Jan 16, 2015, 06:14 PM
Joined Jul 2011
Originally Posted by Bombay View Post
Don't buy a clone. Go for the original, in the original size, original quality, from the original designer - FlyParty
http://stores.ebay.com/EPP-EAGLE
http://www.graysonhobby.com/catalog/...roducts_id=704
You can buy it from his direct US distributor too. Maybe someone will have that link.
Edit: here it is http://www.freewebs.com/eppeagle/
While Flyparty might be the 'original' eagle, there is nothing wrong with a clone if it's a good one! and even better if it's at a more competitive price!
This is by no means a patented design (not that patents mean anything in China) so it's unrealistic to not to expect other manufacturers not to make and sell similar products.
It's safe to say, not all clones are good or bad, in fact some clones have improved on the original in some ways and some have failed miserably, and that refers to ALL RC related stuff.
With that said, Flyparty eagles have allegedly 'better' quality EPP foam than it's 'competitors' and also an inch or so bigger.
Dancing Wings EPP eagles on the other hand, have much better and more realistic looking painted graphics and decent more complete hardware package included at a more competitive price point from Hobbyking. ($78 including motor)
It's all a matter of personal preference and how much you're willing to drop on an EPP eagle. ... Or if you're 'ambitious' enough, you could also build one from scratch from the many online free plans .... at a fraction of the cost
They BOTH (Flyparty & Dancing Wings) fly GREAT! .... when set up properly.
Regardless of what you might pay, you will surely enjoy any one of them, guaranteed!
I personally have the Hobbyking (Dancing Wings) one and I'm VERY satisfied with it.
Discussion EPP Eagle fuzzyhead Foamies (Scratchbuilt) 2 Sep 28, 2008 10:54 AM
