Old Nov 27, 2014, 02:54 PM
Tom Wright's Avatar
Joined Feb 2012
I built a version of Tonys dual axis head today from bits lying around on the bench. The ball joint seems to be remarkably tough and as this head does not require a delta mix it is possible to get loads of back throw to aid spin up in low wind conditions. I fitted two anti yaw plates made from FG , the finished head has no play and the roll arm length is adjustable via a long threaded hex nut.
Tom Wright is offline Find More Posts by Tom Wright
Old Nov 28, 2014, 09:00 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
I have been using mine on my EPP Tadpole Tom and it seems to be holding up very well, am very pleased with it
Simple, easy to make and as you say, gets lot more movement with independent servos rather than delta mixing
Lockey
Lockey is offline Find More Posts by Lockey
Old Nov 28, 2014, 11:52 AM
United States, CA, Monterey
Joined Jun 2010
Tom I am using 1/16 ply shims on the two blade CF which is about what I always seem to end up with, anyhow before I switch motors I will try a few different props to see how it goes this weekend, regards
Kevin
PS love Tony's head design well done.
sepcter is offline Find More Posts by sepcter
Old Nov 28, 2014, 04:55 PM
Tom Wright's Avatar
Joined Feb 2012
Hi Kevin
How far back from the bolt hole outer edge is the shim? If its around 6 mm then you have double the shim thickness I use.
Tonys head design does seem to be practical and easy to build from all sorts of materials
Tom.
Old Dec 28, 2014, 08:26 AM
Tom Wright's Avatar
Joined Feb 2012
Managed to get out on boxing day just before the snow arrived .
Auto gyro Crane Fly (2 min 17 sec)
Tom.
Old Dec 30, 2014, 01:01 PM
Tom Wright's Avatar
Joined Feb 2012
The snow was frozen hard so take offs and landings were no problem ,sorry about the near domestic at the beginning and end.
This Crane Fly is fitted with old blades and has no rudder but even though the wind was near nil ROG was very easy.
SNOW FLIGHT (2 min 50 sec)
For Sale 1/48 20 ton knuckle crane SilentHunter Boats (FS/W) 0 Apr 11, 2012 07:04 PM
Discussion AP -BIG CRANES Working on Bigger Cranes..!.. guyg Aerial Photography 3 Mar 05, 2010 12:26 AM
Discussion Crane & cranes - A\V This Morning guyg Aerial Photography 2 Jan 02, 2008 11:33 AM
Discussion DeBolt Memorial Autogyro Fly In boberos Auto Gyros 7 Mar 02, 2006 10:30 PM
autogyros , anyone fly one? bronco Electric Plane Talk 2 Feb 14, 2002 05:06 PM
