Old Jun 02, 2012, 09:00 PM
Joined Apr 2011
Help!
HK Multi Rotor Control Board MIX
Hello guys, i have looked for a long time a firmware that simply just mix the 4 motors ( a XCopter ) and don't use the 3 gyro of the board.
I want do it because i want to try the flymentor 3D that actually is simple waiting for my hely to be rebuild and also because it could be usefull for making video on a steady position.
Or i just need to know how to mod the firmware of the base xcopter to leave out its own gyro.
Thanks for helping
JackalITA is offline Find More Posts by JackalITA
Old Jun 02, 2012, 11:23 PM
Emress
Joined Nov 2011
dunno why you'd ever attempt this, but it'd be pretty easy to do it on the TX for a + orientation.
you could set all four ESC channels to the throttle stick, and then split pitch/roll for the four motors into each channel, respectively. so, if you pushed pitch up from center(go forward) it would give the rear more power(maybe reduce front too?).
sirbow2 is offline Find More Posts by sirbow2
Discussion Help with HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA) rpscarlets2294 Multirotor Talk 3 Nov 04, 2013 02:29 AM
Hobbyking kk v2.1 multi rotor control board penz83 Aircraft - Electric - Multirotor (FS/W) 2 May 22, 2012 09:27 PM
Help! need help with programming the hk multi rotor board cheechmymarin Multirotor Talk 2 May 07, 2012 11:26 PM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 09:51 PM
Discussion HK Multi-Rotor Control Board animan9 Multirotor Talk 1 Jan 31, 2012 01:49 PM
