Old Oct 18, 2014, 06:47 PM
Addicted To Watts
Joined Feb 2014
what do you guys use to balance Large spinners
Hello
I have purchased a large Xoar Aluminum spinner thinking that it would be of good quality unfortunately it's way out of balance and wants to shake my Mustang to bits
My question is what do you guys use to balance large spinners I have a Du-bro prop balancer but it's too small for this spinner...Any advice / Idea's will be much appreciated
WattsinThat is online now Find More Posts by WattsinThat
Old Oct 18, 2014, 07:02 PM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I use my homemade large prop balancer. It's made from 1/2" square tube and 5/16" threaded rod. It has 2 rare earth magnets on the end and a prop centering shaft from a smaller tool I bought. I can 24" props on this... I simply put weight on the end and hang the business end off the work table. Balance your spinner back plate by drilling large diameter hole(s) partially through it on the heavy end.
scootrb4 is offline Find More Posts by scootrb4
Old Oct 18, 2014, 08:21 PM
Addicted To Watts
Joined Feb 2014
I have managed to balance the backplate the spinner is the problem...thanks anyways
Old Oct 19, 2014, 07:10 AM
media, pennsylvania, united states
Joined Aug 2006
In theory here's how I'd do it. Balance the spinner and prop together as one assembly. Rotate spinner around on backplate so it's least badly out of balance then figure out if you can remove some material from heavy side of backplate or add weight to light side of the assembly. Mark then with a sharpie pen along the edge so they'll assembled back right on the plane.
luckymacy is offline Find More Posts by luckymacy
Old Oct 19, 2014, 01:22 PM
Addicted To Watts
Joined Feb 2014
Maybe my question should have been what do you use to balance large spinners My Du-Bro spinner will not take a 120mm ( 5 Inch ) long spinner
Old Oct 23, 2014, 09:54 AM
Too windy to fly? Lets surf
w1nd6urfa's Avatar
Athens, Greece
Joined Oct 2008
Answer here (towards the bottom): http://www.rcuniverse.com/forum/tips...ncing-how.html
w1nd6urfa is offline Find More Posts by w1nd6urfa
Old Oct 23, 2014, 03:23 PM
Addicted To Watts
Joined Feb 2014
Originally Posted by w1nd6urfa View Post
Thanks I know the basics of balancing..... those spinners on that link are babies compare to the one I have and my problem is that the shaft with the two cones that comes with my Du-bro balancer is just too short to do the job that I need
But thanks anyways
Old Oct 23, 2014, 10:58 PM
w1nd6urfa's Avatar
Athens, Greece
Joined Oct 2008
It's probably not too clear in the above link:
The cones hold the backplate only, the spinner dome is attached to the backplate (use a little tape) so the Dubro shaft length is adequate
I'm currently balancing a 150mm Bf-109 spinner this way, if you want I can post some pics
Old Yesterday, 12:21 AM
Addicted To Watts
Joined Feb 2014
Yeah please do Thanks
Sold Large Scale Wheels and Spinner. flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 1 Sep 26, 2014 11:38 AM
For Sale Enya SS .40 BB engine with muffler and large prop spinner-nut 75.00 shipped. puplover Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 04, 2014 12:29 PM
Found large AT6 type spinner ronj10 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 13, 2013 08:01 PM
Sold Large lot of props, spinners, wheels, and mounts nh4clo4 Aircraft - General - Miscellaneous (FS/W) 2 Nov 04, 2013 11:05 PM
Discussion Prop choice for large diameter spinner camdyson Power Systems 7 Oct 29, 2013 07:46 PM
