Old Feb 07, 2013, 12:33 PM
I fly em', there for I am.
SBOTI74's Avatar
United States, CA, Tehachapi
Joined Feb 2009
Mounting a Vee Antenna help
Hello RCG,
Got a quick question I hope someone can help me with. I did a search yesterday and couldn't come up with any pictures or much information.
I'm just getting into FPV with my Quad and I'm trying to finalize my mounting locations for everything. Here's what I have.
FPV frame from Valuehobby.com
900mhz VTX and VRX
Futaba 9C with Spectrum Module
GoPro Hero 2 (Used for recording and FPV)
So I picked up the 900mzh 500mw VTX with a Vee Antenna from a member on RCG. He's tried to help me with mounting it but I'm still a little confused and he had it mounted on a plane.
Any of you have a Vee Antenna mounted to your quadcopter? Pictures please????
I first thought I could mount the antenna on the back of the frame with the open part of the V parallel with the frame and pointing back. It would look like a pincher bug sort of. But after talking to the seller, I should have the open part of the V facing forward and I get that. But, do I mount it so the V is flat or vertical?
I asked the seller and he said the best way to get better reception is to have the V with one arm parallel with the plane (Quadcopter Frame) and the other part of the V pointing down towards the ground with the open part facing farward.
Does that sound right to you guys? Any pictures out there???
Thank you
SBOTI74 is offline Find More Posts by SBOTI74
Old Feb 07, 2013, 07:26 PM
SBOTI74's Avatar
Joined Feb 2009
Anyone? Suggestions????
Old Feb 07, 2013, 07:40 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Flat or verticle will depend on your GS antenna.
I use a Patch on my GS and it is orientated Verticle so my V antenna is also Verticle.
Make sure the Ground arm of your antenna is down also.
I don't have any Mulitrotor fpv so no pics here.
1320fastback is online now Find More Posts by 1320fastback
Old Feb 07, 2013, 08:44 PM
SBOTI74's Avatar
Joined Feb 2009
Thank you for the reply. Okay, at this time I only have a regular little whip antenna on my GS. Not looking to go that far with it, maybe just around the yard or neighborhood till I get the hang of it.... So do the little whip antennas have a polarity?
What do you mean "ground arm"?
Thank you
Old Feb 08, 2013, 01:41 PM
USA, CA, Oceanside
Joined Jul 2008
V antennas have the signal wire soldered to one of the elements and the shield part of the cable soldered to the other element. This you could consider as the ground element.
Discussion Vee antenna position help ls1elite FPV Talk 7 Feb 07, 2013 11:39 PM
Discussion Best way to mount vee antenna ls1elite FPV Talk 4 Jan 31, 2013 05:03 PM
Discussion Skywalker vee antenna ls1elite FPV Talk 4 Jan 22, 2013 07:51 PM
Sold 1.3GHz Vee Antenna (IBCrazy) Davidpe FPV Equipment (FS/W) 4 Jan 04, 2013 01:35 PM
For Sale 1.3 Ghz Receivers, patch antenna and Vee antenna pyrojets FPV Equipment (FS/W) 0 May 25, 2012 09:10 PM
