Old Sep 21, 2012, 10:21 AM
everything with RC
Brest..."grand ouest"
Joined Nov 2004
Dalotel with kf airfoil
Hi,
Fishing season will soon ended so I am starting a "Dalotel 165" modèle, based on an old MRA magazine, building wtih depron!
I Will share wtih you my fun and pictures are comming soon.
Cheers
Éric
lebardemelon is offline Find More Posts by lebardemelon
Last edited by lebardemelon; Nov 17, 2012 at 11:54 AM. Reason: Mess between languages......
Old Nov 17, 2012, 11:06 AM
everything with RC
Joined Nov 2004
Long Time no see! But not so quietful to start a retirement, to build a ( real) boat and this project together.....
anyway today the Kf wing is finished.
See you soon
Éric
Old Nov 19, 2012, 01:16 PM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
A little known, good looking plane with a reputation as an excellent flier (full or part scale). A Depron scratch build in what appears to be a Park flyer size.
You have my interest, I am subscribed and
Is your airfoil a KFm4?
Appears to have a slight amount of dihedral, is that so?
What is the wingspan?
Look forward to seeing your build progress.
Mazzepa1 is offline Find More Posts by Mazzepa1
Old Nov 19, 2012, 06:42 PM
TonyS
United States, AR
Joined May 2010
Looking forward to your build presentation.
TonyS
tonystro is online now Find More Posts by tonystro
Old Nov 20, 2012, 07:28 AM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
TonyS,
Howdy from a fellow Razorback.
lebardmelon,
Hopefully you are developing plans to share. I really am quite interested in a foam aerobat this size that's not an Extra, Edge or Yak. Not that there's anything wrong with them, I just like something a little different, you know?
Old Nov 22, 2012, 01:08 PM
everything with RC
Joined Nov 2004
No dihedral appears in the MRA plan , so i follow the plan..... It is moreless a kf4 but in fact it is more to give some strenght to the wing.....Only two layers of depron with this 1.4 m wingspan would have been too light according to me.....so i use three.
I use two mini servos HXT500 for the ailerons , it should be OK. I Will use the same miniservos for rudder and and for elevons ( perhaps 2 ..?)
I am less confident for the choice of the motor....but we will see that later.
Cheers to all
Eric
Old Nov 24, 2012, 07:46 AM
everything with RC
Joined Nov 2004
Hi
It is time to redesign the rudder and tail according i only use 6 MM. Depron. It is Quite funny to see that the MRA plan is probably already à translation from impérial messires.
Anyway, that is done and on addition i use some tips to assemble these parts more easily
Nobody havé suggestion for the motorisation choice?
See you soon
Éric
Old Nov 24, 2012, 09:16 AM
everything with RC
Joined Nov 2004
Raining afternoon in Brest
It is done!
Old Nov 24, 2012, 07:07 PM
TonyS
United States, AR
Joined May 2010
Originally Posted by lebardemelon View Post
Hi
See you soon
Éric
Continuing to watch your progress. The plan which you presented in Post #1 indicates the wood and covering model would weigh nearly 2 kilos. A similar size plane available here and powered with a 8.5cc 2-stroke or 10cc 4-stroke glow is reported to weigh about 2.2 kilos.
Your foam version should be lighter so I think a Turnigy 46, or equivalent, would be more than enough power and a Turnigy 32 might be sufficient.
TonyS
Old Nov 25, 2012, 05:19 PM
everything with RC
Joined Nov 2004
Tanks Tony for this estimation about the motor. Of course, the plane Will be Much lighter and I Will make some weigthing soon to be more accurate
Up to now i progress on the tail systems ( spars and hinges) and I started the fuse. About the fuse, i am thinking on how to fix the flat wing to the fuse and to make the "box" rigid enough.....not so simple with Only depron....
Of course, it Will not be a fixed wing because the plane Will travel to the field in a Renault twingo boot....
Old Nov 25, 2012, 05:22 PM
everything with RC
Joined Nov 2004
It seems not possible to attach more than one picture to one post....?!
Old Nov 25, 2012, 05:53 PM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
Are you selecting "Upload Files" before you have all the files selected you wish to post?
1.4 meter wingspan is perfect for what I have in mind.
If you don't have these resources, or something comparable, they may be useful to you.
http://adamone.rchomepage.com/cg_calc.htm
http://www.rcgroups.com/forums/showthread.php?t=966298
Old Nov 26, 2012, 01:23 AM
everything with RC
Joined Nov 2004
Tank you for thèses adresses. That seem very useful.
For the pictures, yes i sélected upload files.
Old Nov 26, 2012, 09:02 AM
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
lebardemelon, have a look at the screenshot I made.
You should click "Attachments" (where the mouse pointer is in the picture), then there should open a new window in which you can upload 150 pictures. (Don't forget to click "Upload" and "Save Changes" in that window)
Hope this helps.
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Nov 26, 2012, 12:22 PM
everything with RC
Joined Nov 2004
I think i understand now.
I word on my IPAD which does not support flash player and everytime i select a second picture to upload, the first one automatically disappear.
Any way that is my "rigid box", built in situ ,directly on the wing.
Help! KF-Airfoils. _ironeagle_ Foamies (Scratchbuilt) 12 Jul 30, 2012 08:47 PM
Discussion KF and other airfoils flyrcusa Scratchbuilt EDFs 14 May 29, 2012 09:31 PM
Poll Post If You Use The KF Airfoil Thread RC Trainer plane Foamies (Scratchbuilt) 23 May 28, 2012 04:47 PM
Discussion F-117 profile Pusher with KF airfoil. burkefj Pusher Prop Jet Models 60 Sep 10, 2008 09:30 PM
Discussion Delta with KF airfoil Terry Rigden Scratchbuilt Indoor and Micro Models 10 Aug 18, 2008 07:07 AM
